10-15-2009, 09:32 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Spain
Member: 453324 Status: Offline Thanks Meter: 54 | ks20 unlock problem? [SOLVED] |
10-15-2009, 10:20 | #2 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | Quote:
first hard reset the phone,then follow this instructions: 1.Type 2676625720#->Port Setting->Diag Setting->USB Set for Diag->Press Ok. 2.Type 2676625720#->Port Setting->USB Switching->LG Composite DIAG->Press Ok. 3.Reboot phone. 4.Press Ok and start code read. tested by me | |
10-15-2009, 12:02 | #6 (permalink) | |
Junior Member Join Date: Dec 2005
Member: 207195 Status: Offline Thanks Meter: 0 | Quote:
I have the same problem here. I try this solution but It still doesn't work. When I upload the file to the phone and try to install it, it always give me "error". Any ideas? Thanks in advance | |
10-15-2009, 12:12 | #7 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | 1. you need to install Microsoft activesync ver 4.5 2. open phone dialer in normal mode and enter 2676625720# 3. phone will enter engineering menu, press for 4.port setting then 2.usb switching 4. select for Microsoft USBfn then click ok on the upper right side 5. restart phone 6. your phone will now be detected as windows mobile device and since you have installed active sync, it will automatically install driver. 7. wait til active sync will synchronize your phone, (note:do not syncronize data - just press cancel if something like that appears) 8. then in active sync press explore 9. download WinDiag_Open.cab 10. paste it somewhere in phone, probably in root directory 11. go back to your phone menu and look for file explorer (if phone is in different language, you will notice its icon if you are familiar with windows mobile device) 12. install windiag_open.cab 13. now you're done 14. back in engineering menu press 2676625720# in phone dialer in normal mode 15. press press for 4.port setting then 2.usb switching 16. select LG Composite - DUN, DIAG 17. restart phone 18. now connect phone using polar box 19. phone is now detected and read for your unlock code. 20. type 2945#*20# for unlock menu entering 21. enter code and now your phone is unlocked. br <= The_Gorr => |
The Following 4 Users Say Thank You to The_Gorr For This Useful Post: |
10-15-2009, 15:02 | #8 (permalink) |
Member: 453324 Status: Offline Thanks Meter: 54 | its ok but not with that procedur with this procedur and about toutou sir these all things are already written in polar so no need to post this if i any body is hart from me i am sorry about that ,but correct procedure for all version are this brother Connecting Phone... Phone KS-20 Found Phone S / W... : KS20FL-01-v10f-214-04-FEB-02-2009+0 Phone Imei... : 357323-01-222062-5 Compilation Date... : Feb 2 200922:33:37Nov 15 200711:00:00KS20 Flash Type... : samsung_k9k2g08 Phone Code... : 0000 Nck Code... : 3182778320071538 Type 2945#*20# Enter Nck Code Unlock Code Readed OK When Finish Unlock Process Remember... - Delete File Active_WinDiag.cab in phone - Type 2676625720# by enter Engineering Menu - Select Opt 2 (Factory Reset) - This Restoring Original Values You tried to unlock Ks20 but you get this error searching phone .. and nothing happened Solution is here - install Microsoft activSync - enter this code : 2676625720# Port Setting → 1. Diag Setting →) 2. USB Switching → “Microsoft USBfn”. - Restart phone - Connect phone with ActivSync - Explore your phone with ActivSync, copy WinDiag_Open.cab to your phone and install it - enter this code : 2676625720# *Port Setting → 1. Diag Setting →) 2. USB Switching → “LG Composite -DUN, DIAG”. - Restart phone - Run Unlock Software ( FG in my case) Do Unlock and you will see must work with all New versions, i dont know if it's old news or not but that helped me and i want to share it with you thx. from this thread:http://forum.gsmhosting.com/vbb/showthread.php?t=570194 |
10-15-2009, 15:03 | #9 (permalink) |
Member: 453324 Status: Offline Thanks Meter: 54 | its ok but not with that procedur with this procedur and about toutou sir these all things are already written in polar so no need to post this if i any body is hart from me i am sorry about that ,but correct procedure for all version are this brother Connecting Phone... Phone KS-20 Found Phone S / W... : KS20FL-01-v10f-214-04-FEB-02-2009+0 Phone Imei... : 357323-01-222062-5 Compilation Date... : Feb 2 200922:33:37Nov 15 200711:00:00KS20 Flash Type... : samsung_k9k2g08 Phone Code... : 0000 Nck Code... : 3182778320071538 Type 2945#*20# Enter Nck Code Unlock Code Readed OK When Finish Unlock Process Remember... - Delete File Active_WinDiag.cab in phone - Type 2676625720# by enter Engineering Menu - Select Opt 2 (Factory Reset) - This Restoring Original Values You tried to unlock Ks20 but you get this error searching phone .. and nothing happened Solution is here - install Microsoft activSync - enter this code : 2676625720# Port Setting → 1. Diag Setting →) 2. USB Switching → “Microsoft USBfn”. - Restart phone - Connect phone with ActivSync - Explore your phone with ActivSync, copy WinDiag_Open.cab to your phone and install it - enter this code : 2676625720# *Port Setting → 1. Diag Setting →) 2. USB Switching → “LG Composite -DUN, DIAG”. - Restart phone - Run Unlock Software ( FG in my case) Do Unlock and you will see must work with all New versions, i dont know if it's old news or not but that helped me and i want to share it with you thx. from this thread:http://forum.gsmhosting.com/vbb/showthread.php?t=570194 Last edited by belli42; 10-15-2009 at 15:06. Reason: i unlock it very easily. |
lg ks20 unlock probleme | abote didier | FuriousGold | 4 | 12-18-2009 19:22 |
problem unlocking - problem solved :) | chachlar | Universalbox | 7 | 12-10-2009 00:42 |
lg ks20 unlock problem | marshalex1 | LG | 5 | 12-23-2008 10:24 |
ks20 unlock problem conection | ali25 | Easy-Unlocker | 0 | 07-22-2008 18:47 |
LG KS20 unlocking probleme | cooloxf | Multi-Box | 3 | 03-24-2008 16:04 |
