12-09-2012, 15:04 | #3 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1061299 Status: Offline Thanks Meter: 0 | Sending Certificate.... Bypassing Security Boot... Bypassing Passed.... Ok... Continue Booting Process...Please Wait... Sending Boot.... Detecting Flash IC. Type .... Flash ID.: 00890004 , Numonyx 32 Mb. Phone IMEI : 356967-04-051104-0 Firmware Ver. : UNI Phone Type : C¹°(Ôxø1ÎË ERROR Phone Not Conected.. Phone Disconnected ... log with boot forced Connecting with phone ... Sending Certificate.... Bypassing Security Boot... Bypassing Passed.... Ok... Continue Booting Process...Please Wait... Sending Boot.... Detecting Flash IC. Type .... Flash ID.: 00890004 , Numonyx 32 Mb. Phone IMEI : 356967-04-051104-0 Phone Connected Ok.. |
12-10-2012, 17:41 | #4 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | I have some questions for you : 1- Why you flashed phone ? 2- Has been touched with any other tool ? This data is not normal and we not write this when we flash Firmware Ver. : UNI Phone Type : C¹°(Ôxø1ÎË 3- Which flashfile did you used it ?? |
05-31-2013, 09:39 | #8 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Inside Polar Box
Member: 71492 Status: Offline Thanks Meter: 119 | Hi Problem found This is not an error of PolarBox In this model, depend of Flash version change addr of write packets in phone Solved this for the next update Regards, Last edited by wendigo; 05-31-2013 at 10:03. |
05-31-2013, 11:26 | #9 (permalink) |
Member: 71492 Status: Offline Thanks Meter: 119 | Hi Please the 2 users with problems contactme polarcdr @ gmail.com Delete spaces Please sendme info about you phone label Example 385X........ Need flash for unlock/unbrand ? Regards |
06-04-2013, 11:21 | #11 (permalink) |
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | We will update today with fixment, be patient pls and download in the next hours the new update for flash and repare it ... |
The Following User Says Thank You to wendigo For This Useful Post: |
06-04-2013, 17:53 | #12 (permalink) |
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Please, download and install this update and try. Confirm us if phone flashed OK. http://www.polarbox2.net/downloads/P...pdate_v327.zip |
06-05-2013, 12:04 | #13 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Spain Age: 40
Member: 975358 Status: Offline Thanks Meter: 67 | i have same problem with 385x-2dbyfr1 , after flash mobile not power on , try with all files from server here is flash log , only connect in boot forced Engine Compilation Build : 327 Connecting with phone ... Sending Certificate.... Bypassing Security Boot... Bypassing Passed.... Ok... Continue Booting Process...Please Wait... Sending Boot.... Detecting Flash IC. Type .... Flash ID.: 00890004 , Numonyx 32 Mb. Phone IMEI : 356967-04-030033-7 Phone Connected Ok.. Changing Speed Up 921600 Bps... Please Wait... Writing Firmware ... Writing PreBlock 1... Writing Block 1... Writing Block 2... Writing Block 3... Writing Block 4... Please Wait... Finishing Writing... Please Wait... Formating... Can take about 60/120 seconds Writing Firmware Ok... Remove Battery and Put again... Phone Disconnected . |
06-05-2013, 12:33 | #14 (permalink) | |
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Quote:
Perhaps this is the problem, so give me few minutes ... | |
06-05-2013, 14:17 | #15 (permalink) |
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Hi friend, I uploaded this new firmwares, please test it. First, test this three for see if phone works : 385a_ALMX1_B34_Firmware() 385x_ALRU1_B34_Firmware() 385x_ALTR1_B34_Firmware() In case not, i prepared this other original firmwares (locked), same than your phone have : 385x_BYFR1_DEFG_Firmware() 385x_BYFR3_I_B75_Firmware() Please, test and report here with some screenshot or copy-paste. With best regards, |
