09-19-2009, 11:49 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 51
Member: 96593 Status: Offline Thanks Meter: 13 | some advice regarding alcatel :: SOLVED :: JUST dont connect no rx tx light on the box,tried 2 cables thanks Last edited by wendigo; 09-19-2009 at 12:41. |
09-19-2009, 12:34 | #2 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Quote:
Can you tell me what cable are you using it ? RJ45 or USB ? (polar works under RJ45 cable) Too, confirm me version of polarbox used (this process is tested and is working ...) With best regards, \W3nd|g0 . PB2 Team | |
The Following User Says Thank You to wendigo For This Useful Post: |
09-19-2009, 13:15 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | and what update version are u using !!! br <= The_Gorr => |
The Following User Says Thank You to The_Gorr For This Useful Post: |
09-19-2009, 14:07 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: A's Phone Clinic
Member: 383961 Status: Offline Thanks Meter: 574 | problem here is on conection cause fone not detect check cable or use pinout |
The Following User Says Thank You to lusandi For This Useful Post: |
09-19-2009, 14:28 | #6 (permalink) |
Member: 96593 Status: Offline Thanks Meter: 13 | ok conection problem solved, another box dongle was also connected and causing problm whn i remove other box dongle connection successfully made now next question is is possible to unlock this model yet 0T 600 many thanks |
09-19-2009, 14:38 | #7 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | good then , about ot600 if 600x, use 600x_(Unlock-Unbrand) flash to unlock it if 600a (only flash is supported, u have to wait for unlock) br <= The_Gorr => |
09-19-2009, 14:44 | #8 (permalink) |
Member: 96593 Status: Offline Thanks Meter: 13 | many thanks again to polarbox team supporters excelent support simple clear and rapid response regards fx1 |
The Following User Says Thank You to FX1 For This Useful Post: |
need advice regarding 2610b 7.04a | elizar28 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 11-14-2009 09:07 |
.:: Big problem with a 5200 ::. [SOLVED] | The_Dj | Cyclonebox | 16 | 09-25-2009 11:17 |
:: Alcatel IMEI Unlock :: | UnlockByLogs | All UnlockByLogs Server | 8 | 12-19-2008 20:37 |
Some questions regarding T191 & DMTools | BufferMess | Motorola ODM | 2 | 11-26-2002 08:50 |
I need some advice about hot air station... | sifasli | Hardware Repair by brands | 4 | 03-02-2002 18:15 |
