09-17-2009, 11:15 | #1 (permalink) |
selective member algo bruteforce SL3 Join Date: Dec 2007 Location: IRELAND
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | URGENT HELP NEEDED >> BLACKBERRY 8800 not reading in PandaBox Suite v1.0.8 :ANSWERED: Code: Selected : Blackberry 8800 Reading Data...Please Wait... BGUID : 7B3A34633E3F326CAB65D23EBBB484DF844C25D6 BPIN : 25364969 Last edited by rotelcam; 09-17-2009 at 13:14. Reason: Remove Box S/N |
09-17-2009, 11:35 | #3 (permalink) | |
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | Quote:
I have did - nothing have changed, tried on two different laptops, still the same! It looks like it would be something to do with connectivity betwen phone and laptop. Have tried over 10 different lenght different quality USB cables, didnt solve the problem... Tried to restart the phone still the same ... Dont know what else to do... | |
09-17-2009, 17:52 | #8 (permalink) |
No Life Poster Join Date: Oct 2008 Location: WHERE THE WORLD ENDS
Member: 885625 Status: Offline Sonork: 100.1589108 Thanks Meter: 2,432 | hi friend you are sure that user code is active?if yes did you know the user code?if yes go to security settings you will find option to disable user code.all the best suunnyy |
09-17-2009, 18:02 | #9 (permalink) | |
This phone has been on corporate BES setup. You can't disable/delete code without reflashing it to normal SW. IT Policy requires a password be used, unless you reflash phone. I know code even when phone menu is unlocked active for use it still does not connect! Customer will backup all his data and will come back to me tomorrow for reprogramming and unlocking of this BBRY This makes good sense that POLARBOX2 needs some improvements of walking-trough this security. BR | |
09-17-2009, 18:33 | #10 (permalink) |
No Life Poster Join Date: Nov 2003 Location: kjhjk Age: 50
Member: 43253 Status: Offline Thanks Meter: 157 | If you have an user password and you can´t disable it (and although you reset it, it still requesting), Look for this soft JL_Cmder_v1.9.1 and make a factory reset (use option resettofactory), I had a bb that had a lock in disable/enable password option, and with this soft I could disable it. Post result. |
09-17-2009, 19:47 | #12 (permalink) |
Member: 43253 Status: Offline Thanks Meter: 157 | I used the JL_Cmder_v1.9.1 with one bb 8700, and remove the restriction to change the password Enabled/Disabled option. It is an small program in MS-DOS |
09-18-2009, 08:45 | #13 (permalink) | |
Please let me know how did u use it in ms-dos command line? its win32 executable I have found on www.4shared.com ... its just below 200kb size. it asks for instalation and then closes down after launch immediately.. please upload file and PM me a link, thanks BR | |
09-18-2009, 14:40 | #15 (permalink) |
Member: 43253 Status: Offline Thanks Meter: 157 | Look in your PC in C:\Program Files\JL_Cmder\ and run this JL_Cmder.cmd Use it at your own risk, I used with one 8700 and not problem. (Sorry for the double post, my conection today is very slow) Last edited by pititi1974; 09-18-2009 at 14:46. Reason: Missing explication |
urgent help needed for blackberry 8820 | burraq | BlackBerry (RIM) | 5 | 02-13-2009 08:21 |
Urgent Help Need 6085 Shows Charger Not Supported | joni_rajpura | Nokia Hardware & Hardware Repair | 7 | 01-27-2009 06:09 |
PLEASE HELP-upgrade sucsessfully but ufs not connected with hwk suite v_2.0.7 | Rajan chhetri | UFS2 + UFS3-Tornadoflasher | 6 | 09-18-2008 12:22 |
