10-08-2008, 16:19 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Vodafone 810 (Blocked counter) PB Team read this post ::SOLVED:: My friend @Y3KT unlock a Vodafone 810 as shown here: by reading the code with MicroBox as can be noticed, but already the phone because he had been ill and had 5 tries out the meter, something that made him my super PolarBox2 unlock direct, but that my address is strange what happened. Now the Vodafone 810 will be only 2 lines can be different even from the same company, where he puts the third says, locked in counter, check provider. To analyze in detail that may be happening Very thanks in advanced to PB-Team br elcapitel |
10-08-2008, 17:30 | #2 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Quote:
but please explain me because i not understand what u are telling ... You mean bad unlock by microbox or bad unlocked by polar ? Or what u are trying to say (Im confussed) With best regards, PB2 Team | |
10-08-2008, 17:42 | #3 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | @Wendigo In engish: -------------------------- sorry for my bad English. I mean the MicroBox him by the reading procedure code correctly but failed in the process of resetting the counter. All the contrary with PolarBox2, made the process of unlocking direct correctly, but now something very strange happens. Is completely unlocked, but only for the first 2 lines to be placed, after the release process with polar, and when you are makes the third line, albeit from the same company for either of the 2 above, the Vod810 said: Telephone blocked attempts and 5 losers. It is very strange that, at least for me, obviously something strange going on in the process of release. En español: ----------------------------- Disculpa por mi mal inglés. Yo quise decir la MicroBox le hizo el procedimiento de lectura de código correctamente pero falló en el procedimiento de reseteo del contador. Todo lo contrario con PolarBox2, hizo el proceso de desbloqueo directo correctamente, pero ahora pasa una cosa muy extraña, está liberado completamente, pero únicamente para las primeras 2 líneas que se le pongan, luego del proceso de liberación con polar, y cuando se le pone la tercera línea, aunque sea de la misma compañía de cualquiera de las 2 anteriores, el Vod810 dice: Teléfono bloqueado, y 5 intentos vencidos. Es muy extraño eso, por lo menos para mi, evidentemente algo raro pasa en el proceso de liberación. Discúlpame por poner el mensaje en español, se que va contra las reglas del foro, pero es necesario para que me entienda lo que quise decir, usted puede añadirme también a mis messenger: [email protected] [email protected] y conversamos en detalles. br elcapitel |
10-08-2008, 18:42 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | What he wanted to say is that with the box i used i could read the codes well, but phone was counter blocked, and as i could not enter the NCK provided i asked him to use PB direct unlock solution, direct unlock seem to work ok, but after we tried with to different sim cards everything was, when used a third one the phone showed us the same message as before it was unlocked, Counter Block... NCK enter 5 times wrong...., the fact is that after the unlock the phone accepts only this two simcards we used first, no matter if we used another card from the same company, and that is very strange, hope you undersatnd now, luck |
10-08-2008, 18:57 | #6 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | yes clear, but try this : try to unlock phone again and test try with any other blocked counter but don't test with micro, use only polar and check will check also from my side, but till now no one of polar user, that used directly polar box (without testing with other box) , get this problem br <= The_Gorr => Last edited by The_Gorr; 10-08-2008 at 19:03. |
10-08-2008, 19:00 | #7 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | ok we are going to try but microbox does not write on the phone it just reads the codes, and please try with three different simcards the next one you get in your hands, luck |
10-08-2008, 22:16 | #8 (permalink) | |
Hi again, Well y3kt, now i tested to block one Vodafone V810 (NCK Counter Bloqued) and I unlocked directly with polarbox2. After this i tested with 5 different cards and always is unlocked. Then POLARBOX2 works perfectly. About competitor box, u told me that you make READ NCK. As i know, they make READ NCK and CLEAR COUNTER. Cause seems they not clear the NCK COUNTER (as you confirmed to me) can exists 2 options. a) They not send clear command (i assume not, cause they announced) b) They overwrite data in incorrect address. The "B" option can overwrite simlock area, and give phone making strange things. If you after this make DIRECT UNLOCK with polar, polar only will recalc. correct data (if exists other data corrupted phone will be locked to all networks.) And the most important : PolarBox2 do real SERVICE calculation of simlock area and do not modify other area. Modify other area like looking data in FFS structure and change can cause strange things with phone. Best will be make this test yourself with phone ONLY TOUCHED by polar, and not after. I hope u can test and post results here. With best regards, \W3nd|g0 . PB2 Team Last edited by wendigo; 10-08-2008 at 22:23. | |
The Following User Says Thank You to wendigo For This Useful Post: |
10-09-2008, 12:11 | #10 (permalink) | |
\With best regards, \W3nd|g0 . PB2 Team | |
10-09-2008, 13:18 | #11 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Well, my friend elcapitel has done interesting findings about this, let's wait he post what he have found. Just to let you know, we did second direct unlock to my v810 and it does not accept any simcard, but those first two we tried, it is indeed very strange, so i will have to wait until someone can repair it, luck |
10-09-2008, 13:41 | #12 (permalink) | |
As i told u, polar make full recal. of the simlock area. if this phone is damaged, i assume only flashing will get to original state. This phone is overwrited in incorrect addresses ... Read my previous words : (if exists other data corrupted phone will be locked to all networks.) Check entire polar subsection and post about unlock of this phones. You will see that no errors and no post about failing, and I not erase threads or posts about bugs or mistakes. The only bug is driver detection (v715 v716) and is solved selecting Plusfone 603i (already fixed in new polar suite) But this make polar cant detect phone, no other thing ... With best regards, PB2 Team | |
10-09-2008, 14:16 | #13 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Dont worry, i am not blaming anyone, there are also many succesfull posts of unlocking this model in the other product's section, we just wanted to know what was and is happening with the one i have specifically, regards! |
10-10-2008, 18:52 | #15 (permalink) | |
Please read this ... http://forum.gsmhosting.com/vbb/showthread.php?t=608930 With best regards, PB2 Team | |
read this mcn .::SOLVED::. | iwan8818 | McnPro Box | 4 | 04-09-2009 20:41 |
vodafone 810 phone password. how can remove this ? | hussainafridi | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 04-04-2009 08:42 |
vodafone 810 blocked | spider-man | Various | 13 | 11-04-2008 07:45 |
new idea:) multi-box team read this... | krzysztof.kt | Multi-Box | 2 | 04-20-2006 17:03 |
