04-19-2008, 14:04 | #1 (permalink) |
Junior Member Join Date: Apr 2008
Member: 754154 Status: Offline Thanks Meter: 0 | learner question > unlock my E220 Please be kind not very PC aware, took me all morning to post this message. A little help please I have two Huawei E220 modems one on THREE other on T-mobile both work ok on there sims With the THREE modem in the application reads Looking for phone... Phone detected. Phone Model: Huawei E220 Firmware serie: E220 Phone IMEI: 358954-00-360**** Serial number: E05TAA181243**** Firmware Version: 11.117.08.05.156 Simlock status: Disabled All Done! - Time:00:00:02 but the t-mobile sim will not work in the modem says 'invalid sim' So, is this unlocked or not ?? if not , can it be unlocked ??? cheers from an old man who's having a nightmare |
04-20-2008, 09:42 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006
Member: 384655 Status: Offline Thanks Meter: 517 | copy/paste from SW, so all what U see Usage: 1. Remove SimCard and plug PCMCIA Modem (KK name it phone). 2. Install drivers (from our support). 2a. For Huawei E220 card with non supported firmware then read "WARNING". 3. Click "READ INFO" to check simlock status. 3a. If client will read strange or non complete data click "READ INFO" again... 4. Click "EXECUTE",wait when finish and enjoy. WARNING: Huawei E220 cards must be flashed at least with firmware from support(11.116.05.00.00.B268) or newer!. !!! Remove SimCard while simlock operation! Otherwise simlock status will be incorrect !!! b.r. Quote:
05-31-2008, 08:38 | #3 (permalink) |
Junior Member Join Date: May 2008 Location: Philippines
Member: 782379 Status: Offline Thanks Meter: 0 | Since your modem seems to be unlocked... maybe you can also check whether you have installed the SIM properly... when reversed or wrong orientation... it will display Invalid SIM... happened to me a couple of times. |
Successfully Unlock Huawei E220 HSDPA USB Modem !!! | CNW | KULANKENDI Server | 10 | 05-16-2008 08:08 |
Error: Internal! > COM port routine > 1 Huawei E220 | bobey77 | KULANKENDI Server | 6 | 04-14-2008 21:42 |
which cable should we use for unlock ALCATEL E220 ? | black snake | Multi-Box | 2 | 10-20-2007 14:49 |
unlock ot-e220 | VolcoM | Easy-Unlocker | 2 | 09-04-2007 12:22 |
