Important Info about J750 unlocking and wrong codes 1 Attachment(s) Important Info about J750 unlocking and wrong codes For ALL who have wrong code problem just be patient, me too i have this prob and prob solved now, this prob will be fixed during the day. And about cable connexion just make a modification to connect using RJ45, see attachement for correct cable. Thanks Br EMINEMGSM |
thanks EMINEMGSM i will try now, |
thx for this solution |
problum worng code on j750 plese solve this Phone info: ~~~~~~~~~~~ Phone Model: Unknown IMEI: 356594015807722 Connected to server Unlock codes: ------------- UNLOCK NETWORK LOCK: #7465625*638*19341362# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# |
is it important to modifie combo cable to unlock j750...any othere solution plz...coz i have only one cable in hand .....thxs in advance ....ikrash |
No wrong codes,Codes 1000% correct No wrong codes,Codes 1000% correct All codes are correct, prob not in easy software, sw read codes correctly, but prob it's in samsung phones, sometime can't accept code. And exist many problems with diffirents firmware versions. For exemple i have this phone from orange frnace i get this code: Phone info: ~~~~~~~~~~~ IMEI: 356594015366042 Unlock codes: UNLOCK NETWORK LOCK: #7465625*638*20615719# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# Phone don't accept this code i pass it with operator log i get the same code: 20615719 So prob it's in phone not in sw. Hope will find solution for this problem Br EMINEMGSM |
if problem still in some firmwares version, who can't accept code, just try with different or old firmware with BCM2133 Downloader br :) |
same problem wrong code :) who can share flasher and flash :D Thanks |
same here just right now i have tryied with 2 j750 and 1 j400 and i get wrong code message .is there any solution now or we have to still wait for any solution. thx br. |
after modifide cable this errer Phone info: ~~~~~~~~~~~ Phone Model: SGH-J750 Revision: Telstra: r1.8 patch 3 IMEI: Manufacturer: SAMSUNG Connected to server Unlock codes: ------------- No unlock codes available! Disconnected from server |
hello not work for me tryed from 0 to 9 on last digit always erroe code the freeze and unfreeze code work salam |
The phone was freezed and at first conection I received just unfreeze code, after unfreeze I got just: No unlock codes available! Can we unlock such phones via easy-unlocker? |
This is what I just got with one J750. It only reads the model Phone info: ~~~~~~~~~~~ Phone Model: Unknown IMEI: 356594011065101 Connected to server Unlock codes: ------------- No unlock codes available! Disconnected from server |
