02-29-2008, 16:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: GSMHOSTING Age: 42
Member: 57652 Status: Offline Thanks Meter: 1,893 | Important Info about J750 unlocking and wrong codes For ALL who have wrong code problem just be patient, me too i have this prob and prob solved now, this prob will be fixed during the day. And about cable connexion just make a modification to connect using RJ45, see attachement for correct cable. Thanks Br EMINEMGSM |
The Following 3 Users Say Thank You to EMINEMGSM For This Useful Post: |
03-01-2008, 12:57 | #4 (permalink) |
Freak Poster Join Date: May 2006
Member: 281468 Status: Offline Thanks Meter: 24 | problum worng code on j750 plese solve this Phone info: ~~~~~~~~~~~ Phone Model: Unknown IMEI: 356594015807722 Connected to server Unlock codes: ------------- UNLOCK NETWORK LOCK: #7465625*638*19341362# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# |
03-03-2008, 14:49 | #6 (permalink) |
Member: 57652 Status: Offline Thanks Meter: 1,893 | No wrong codes,Codes 1000% correct No wrong codes,Codes 1000% correct All codes are correct, prob not in easy software, sw read codes correctly, but prob it's in samsung phones, sometime can't accept code. And exist many problems with diffirents firmware versions. For exemple i have this phone from orange frnace i get this code: Phone info: ~~~~~~~~~~~ IMEI: 356594015366042 Unlock codes: UNLOCK NETWORK LOCK: #7465625*638*20615719# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# Phone don't accept this code i pass it with operator log i get the same code: 20615719 So prob it's in phone not in sw. Hope will find solution for this problem Br EMINEMGSM |
03-04-2008, 16:19 | #10 (permalink) |
No Life Poster Join Date: May 2006
Member: 275861 Status: Offline Sonork: 100.111 Thanks Meter: 166 | same here just right now i have tryied with 2 j750 and 1 j400 and i get wrong code message .is there any solution now or we have to still wait for any solution. thx br. |
03-04-2008, 17:04 | #11 (permalink) |
Freak Poster Join Date: Jul 2005 Location: .........
Member: 165303 Status: Offline Sonork: 100.1580123 Thanks Meter: 57 | after modifide cable this errer Phone info: ~~~~~~~~~~~ Phone Model: SGH-J750 Revision: Telstra: r1.8 patch 3 IMEI: Manufacturer: SAMSUNG Connected to server Unlock codes: ------------- No unlock codes available! Disconnected from server |
03-06-2008, 20:27 | #14 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: Moldova Age: 48
Member: 55917 Status: Offline Sonork: 100.1583632 Thanks Meter: 35 | Quote:
The phone was freezed and at first conection I received just unfreeze code, after unfreeze I got just: No unlock codes available! Can we unlock such phones via easy-unlocker? | |
03-07-2008, 11:00 | #15 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Spain
Member: 9489 Status: Offline Thanks Meter: 35 | This is what I just got with one J750. It only reads the model Phone info: ~~~~~~~~~~~ Phone Model: Unknown IMEI: 356594011065101 Connected to server Unlock codes: ------------- No unlock codes available! Disconnected from server |
Important info about T9 | Bilekas | E-Gold Based Phones | 5 | 01-05-2005 23:42 |
Info about 922 4.1M Wrong Code Counter | JSB | Infineon C16X M51 & ARM7 M52 BASED | 0 | 12-23-2000 12:11 |
