samsung m610 unlock What about m610 unlock? Can it be supported? thanks PS> and lg kg130..... need update pls |
M610 unlock, use E210 cable and select X550, remember only use the RJ45 not plug the USB part of the Combo cable for making this model, Regards |
Yes! I did everything as you say, but with X550 not have connected phone, with E250 phone is connected, but can not pass security MSL. This is bug!!! I have tested 5 phones, always same thing! What is it? |
how to unlock, please post screen shot our other info about this, then we able to solved your problem |
1. Run Sam2G_EU 2. Selecte X550 3. Cable E210 but only RJ45 4. Conecte cable, phone power by on is alone Bypassing MSL security... (Press PWR ON on phone) ERROR - Can't connect to phone! Port: SphereGSM Fighter Cable Speed: 921600 |
possible reasons: your phone ON, you are try to unlock your cable is not good (check cable) your phone jack is not good (check phone Jack) remove cable from phone, after press job(unlock) then connect cable and press power button from phone, PS: where is screen shot ??? |
some problem E210 too ! tryed.. x550 c170 etc etc Bypassing MSL security... (Press PWR ON on phone) ERROR - Can't connect to phone! sm4rtboy |
please we need screenshot for help, post screenshot please |
@SM4RTBOY really need good support ? always post screen shot with your's problem |
I had alot of similar problem, the solution was always the comp port, try to change the com port before any other thing, if not working post screen sh to the supporter and he will solve the problem. |
I can't succeed to unlock a single M610 with eubox. |
can you post here how you try to unlock? |
EU dont work with M610! |
