01-23-2007, 08:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Phils
Member: 331390 Status: Offline Thanks Meter: 434 | L6 dead Split input file in codegroups: Processed ok Establish connection to handset FLASH Interface established ok Sending RAMDLD to handset RAMDLD started ok in handset Erase flash... Err no: 01120004 Err no: 01240004 please help! |
01-23-2007, 10:03 | #4 (permalink) | |
No Life Poster Join Date: Jan 2006
Member: 219831 Status: Offline Thanks Meter: 104 | Quote:
hi if show b l then try dont use tp, direct flash. may be help u Amit Tank | |
01-24-2007, 03:30 | #9 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sheffield
Member: 26187 Status: Offline Sonork: 100:77458 Thanks Meter: 290 | this is so easy to fix guys the problem normally happens at the first take battery out an d re-insert solution close and re-launch software select correct model take battery out of phone and re insert connect to box you will see phone connect in boot mode (its still blank, not dead) press "unlock" button let process finish take out battery and cable insert battery and connect to cable now press leave blank and follow prompts job done |
01-24-2007, 06:14 | #10 (permalink) | |
Member: 331390 Status: Offline Thanks Meter: 434 | Quote:
the results..the UBL soft always hang.. help pleasse UBL team.. | |
01-26-2007, 09:50 | #12 (permalink) | |
thanks mate, but i dont have infinity box.. maybe this is a bug,please UBL team,take a look at this.. | |
01-26-2007, 12:13 | #13 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 420649 Status: Offline Thanks Meter: 414 | Quote:
If you will plug out USB cable from phone when software hanges you will receive error numbers. Press Repair now when phone is in Blank mode. After that flash phone with 1FF file. | |
01-27-2007, 06:38 | #14 (permalink) | ||
what's next? | ||
L6 Dead after Unlocking with Smart Moto " PHONE CODE SIG ERROR " | Aamir_Zia | Smart-Clip | 53 | 06-13-2006 19:27 |
L6 dead trying to unlock | SilentKiller | Smart-Clip | 12 | 02-28-2006 02:31 |
L6 Dead กกก I Need Flash !!! | Irix | Smart-Clip | 1 | 01-27-2006 13:29 |
L6 dead after Unlock | Ran | Smart-Clip | 0 | 01-05-2006 01:58 |
L6 dead (gsmserver help) | doudiunlocker | Smart-Clip | 4 | 12-30-2005 02:22 |
