01-22-2007, 12:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Denmark Age: 45
Member: 4205 Status: Offline Thanks Meter: 9 | Bootloader suddenly E000 - and not supported! Even though the logs says, there are backups saved - I can't find these? Log (identical for both phones): Establish connection to handset Switch handset to TCMD interface Switch handset to FLASH interface FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A30 Sending RAMDLD to handset RAMDLD started ok in handset Read flash backup from handset Save flash backup Finded fake sign address: 10004958 Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A30 Sending RAMDLD to handset Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0000 Sending RAMDLD to handset RAMDLD started ok in handset Read Flash chip type and ID Flash chip ID detected: 0x0020880E Direct unlock method selected Started unlocking sequence Power down handset Unlocking sequence completed ok Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: E000 ERROR: Not supported Model/Bootloader! |
01-22-2007, 12:37 | #2 (permalink) | |
Junior Member Join Date: Dec 2006 Location: Gsm Hosting
Member: 421978 Status: Offline Thanks Meter: 0 | Quote:
Try to flash Complite with mss4 Tune HOuse The Band of Enggineares | |
01-22-2007, 12:46 | #4 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | i have just killed a v3i the same as above. yesterday it killed a e1000 and i had to fix it with smart clip. i only brought it to fill in while i was waiting for scard. i have never killed a phone with smart-clip in two years and 1000+ phones. just goes to show, you get what you pay for, cheap money=sh1t tool. will never use again. |
01-22-2007, 13:13 | #5 (permalink) |
No Life Poster Join Date: Apr 2002
Member: 10964 Status: Offline Thanks Meter: 285 | i solved my phones by removing blank mode had same pb today on V360, V235 and i have a blinking V190 - unlock was succesfull on this one this is just after update please verify this last update - it has a problem br sorinm |
01-22-2007, 14:23 | #6 (permalink) |
Member: 4205 Status: Offline Thanks Meter: 9 | Remove "Blank Mode" gives this: Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Try to load backup file ERROR: Cannot find backup file As I said earlier: I doesn't look like a backup file was created (even though GOT said so)! :-( |
01-23-2007, 11:54 | #10 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Kenya
Member: 70343 Status: Offline Thanks Meter: 38 | Try removing from blank mode, under repair. I had a v3x which gave the same error message after unlocking. After removing blank mode it powered up normally, was unlocked, and is still working fine. |
01-23-2007, 12:31 | #11 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
just need to remove blank but at same pc..becuse got or ubl done some backup that need to restore.. that restore done with remove s blank with GOT and restore done if u done in UBL with botton leve blank. | |
01-23-2007, 12:47 | #12 (permalink) |
Junior Member Join Date: Dec 2004 Age: 52
Member: 100060 Status: Offline Thanks Meter: 0 | hi same problem treid to unloock v3i but now not powering on...connects ok ...tried remove blank but get " not supported " message...will i need to full flash am on download link I didnt make full note of software version and there are many different ones of v3i R479_g is all i got dont want to download and flash with wrong file...if that is what i have to do? pls |
01-23-2007, 12:53 | #13 (permalink) |
Member: 104911 Status: Offline Thanks Meter: 42 | 100% incorrect: Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Try to load backup file Sending RAMDLD to handset Error: 20020302 of course i tried that yesterday, still dead after two days and sh1t support. |
01-23-2007, 12:56 | #14 (permalink) | |
and press remove blank pls attach image here. | |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
[MXKEY-INFO] post here only unsucessfull and not supported mep:) (Answered) | sahil2000ind | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 3 | 02-28-2010 23:23 |
J70 suddenly locked and not unlockable | jeanfleur | Sony | 2 | 02-05-2007 23:03 |
Unlocking L& SLVR - ERROR: Not supported Model/Bootloader! | kivvv | Motorola P2k | 3 | 01-29-2007 06:57 |
A1000_ bootloader 01.02.11 My Clip or Not Supported? | blaiseid | Smart-Clip | 10 | 11-01-2005 21:17 |
