02-05-2007, 15:36 | #1 (permalink) |
Junior Member Join Date: Mar 2006 Age: 51
Member: 246198 Status: Offline Thanks Meter: 0 | G.O.T locks up on me when unlocking certain models. Basically everything goes well until the point when it sets blank mode, then G.O.T locks up on me and I can't do anything but launch another copy. At this point the phone is stuck in blank mode and I can't get it out unless I use my smartclip. This has happened to me with an L6, a v190 and just now with a V557. Originally I thought it may have something to do with my PC, so today I restarted my PC and took a v360 of my own and unlocked it using the Easy Skip procedure and all went fine. Then I tried the V557 and I got the same problem I described above. Is anyone else having this problem? Did G.O.T change anything with this version that is making it not work well with windows 2000? I hope G.O.T support team can help me figure this problem out. |
02-06-2007, 17:08 | #4 (permalink) |
Member: 246198 Status: Offline Thanks Meter: 0 | I'm really starting to think that there is a problem with version 45. Here is a log from an easy skip Tp attempt on an L7: Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A20 Sending RAMDLD to handset RAMDLD started ok in handset Read flash backup from handset Save flash backup Finded fake sign address: 1000499C Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A20 Sending RAMDLD to handset RAMDLD started ok in handset Set handset to blank mode Power down handset Set Blank Mode completed ok Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A20 BLANK MODE or TESTPOINT required for this model and bootcore |
02-06-2007, 17:16 | #5 (permalink) | |
Member: 246198 Status: Offline Thanks Meter: 0 | Quote:
Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A20 Sending RAMDLD to handset RAMDLD started ok in handset Read flash backup from handset Save flash backup Finded fake sign address: 1000499C Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A20 Sending RAMDLD to handset RAMDLD started ok in handset Set handset to blank mode Power down handset Set Blank Mode completed ok Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Sending RAMDLD to handset RAMDLD started ok in handset Read Flash chip type and ID Flash chip ID detected: 0x00898810 Direct unlock method selected Started unlocking sequence Power down handset Unlocking sequence completed ok Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Try to load backup file Sending RAMDLD to handset RAMDLD started ok in handset Recover handset from blank mode Power down handset Handset recovered from blank mode Easy Skip TP unlock finished ok But, now the phone does not want to come out of blank mode. Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Try to load backup file Sending RAMDLD to handset RAMDLD started ok in handset Recover handset from blank mode Power down handset Handset recovered from blank mode | |
02-06-2007, 20:51 | #6 (permalink) |
Member: 246198 Status: Offline Thanks Meter: 0 | And the hits just keep on coming. I finally got the L7 to work, after some flashing and PDS repairing. So at this point, I've pretty much given up on using the easy skip TP with this version of G.O.T Now I have a Razr V3 with bootloader 08.29 to unlock so I decide to use the Testpoint method...... Guess what? It just hangs after reading the bootcore version and the program freezes. At this point, I'm thinking it MUST be my system...... So I launch another instance of G.O.T and try doing a Testpoint unlock on a V3r with bootloader r3443_u2 But this phone unlocks just fine. What is up with v0045 of G.O.T?? I find it hard to believe that my computer is picking and choosing which phone it wants to work with. Any help will be appreciated. Oh yeah here is the log of my V3r unlock which was successful. The RED text is where G.O.T froze on me while atttempting to unlock the V3 with Bootloader 08.29: Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Sending RAMDLD to handset RAMDLD started ok in handset Read Flash chip type and ID Flash chip ID detected: 0x0020880E Direct unlock method selected Started unlocking sequence Power down handset Unlocking sequence completed ok |
02-07-2007, 13:57 | #7 (permalink) |
Product Supporter Join Date: Nov 2006
Member: 394070 Status: Offline Thanks Meter: 14 | @LetsGoCellular: 1. We will investigate what exactly happens in v0045 on your reported models. 2. Regarding your last post, is totaly unusefull, that because V3 (the one with BL 0829) is LTE based platform and V3r is LTE2 based platform. Totally differenet phones! Is same difference like DCT3 and DCT4 on Nokia phones. Even if V3 looks almost same like V3r! |
02-08-2007, 08:17 | #8 (permalink) | |
After setting the phone to blank mode, G.O.T tried to send ramldr to phone and G.O.T locked up on me once again. Now the phone is stuck in blank mode | |
02-08-2007, 22:34 | #9 (permalink) |
Junior Member Join Date: Nov 2006
Member: 389414 Status: Offline Thanks Meter: 0 | Me too...just tried to unlock 2 V3s R374_g and GOT locks up after message...send ramldr to phone. Need to restart computer as there is no way to stop the program. (win2000) Any chance you can sort it or roll back to an earlier release before my credit runs out friday afternoon??? Ta muchly |
02-08-2007, 22:53 | #10 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | I was having the same problems, that's because I had installed Motorola Drivers 2.6.2 (last release), when phone was in "Modem Mode" GOT doesn't recognice phone and shows "NOT CONNECTED" I had to switch it manually to P2K MODE to be recogniced by GOT, and the program stucks in certains operations. I go back to 2.2.0.0 release of Moto drivers and now everything is working as usual. I think that GOT stuks problems are a driver-related issue. @all with the same problem, please post results with this solution. BR jepetu |
02-09-2007, 00:44 | #12 (permalink) | |
But, I reinstalled my drivers after your post just to make sure they weren't somehow updated and I can report that I am still having the same problem. So it does not appear to be the solution. If I'm not mistaken; other then a v360, I don't think I successfully unlocked a phone using the Easy Skip TP method with version 45. Although the TestPoint method has been working fine..... So far. | |
02-09-2007, 20:23 | #14 (permalink) | |
Product Manager Join Date: Jan 2006 Location: 亚洲 / Asia Age: 36
Member: 222198 Status: Offline Sonork: 100.102981 Thanks Meter: 3,813 | Quote:
https://forum.gsmhosting.com/vbb/f396/how-flash-v3r-r4515_g-374754/ B.R., Viru | |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
please help me for unlocking sendo model. | paxji | Multi-box LITE | 1 | 02-02-2010 23:44 |
Pls help me to unlock this model LG KM710D | oraj | Octopus LG/Octoplus LG | 3 | 01-18-2010 19:11 |
help me for unlocking this model !!!!!!!!! | nejm | FuriousGold | 4 | 11-07-2009 10:40 |
