01-22-2007, 21:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | V3 R374_G Problem I've tried to flash it with R374_G_0E.40.3ER_A_LP0039_DRM0001_JPJAVA_G_0E_V3_0 1_08R_SE8621AXXB1046_1FF.gtc but GOT give the following errors: Split input file in codegroups: Processed ok Establish connection to handset FLASH Interface established ok Sending RAMDLD to handset RAMDLD started ok in handset Erase flash... Error: 01120004 Error: 01240004 Please I need to know what are the next steps I should take to recover the handset. TIA jepetu |
01-22-2007, 23:53 | #2 (permalink) |
No Life Poster Join Date: Sep 2004 Location: www.thefonedoc.com Age: 55
Member: 84155 Status: Offline Thanks Meter: 8 | Using Sure GOT Select the Motorola Original Files SHX heading Then the V3 sub heading Then 0E.40.3ER_A sub heading Try a flash from there and see what happens |
01-23-2007, 01:41 | #3 (permalink) | |
Member: 181633 Status: Offline Thanks Meter: 730 | Quote:
Split input file in codegroups: Processed ok Establish connection to handset FLASH Interface established ok Sending RAMDLD to handset RAMDLD started ok in handset Erase flash... Error: 01120004 Error: 01240004 TIA PD: I've allready tried a 1FF SHX from 'Motorola Original Files' and GOT gives the same error, I don't know how to continue. | |
01-23-2007, 12:06 | #4 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @jepetu you have this boot loader in phone 08.23? for flashing u need to downgrade boot loader then ur able to flash.. so simple unlock frist. its make loader downgrade and flash it.. |
01-23-2007, 23:56 | #5 (permalink) | |
One thing when the phone has BL 0826 it olny start in flash mode (as with BL 0823 when the screen was blank) but the screen shows 'BL 08.26, SW: R374_G_0E.40.3ER_A, PHONE CODE SIG 35:02:" @gotsupport Can you helpme please to revive this handset? TIA | |
01-24-2007, 23:02 | #9 (permalink) |
Member: 181633 Status: Offline Thanks Meter: 730 | @stanner_austin Man don't be mad, I only espect help from anyone and I will be gratefull if that help came from YOU, sorry if I have been misunderstood. I said '@gotsupport' because this is a payed-product support area and is logical that if we are talking about 'error numbers' gotsupport should be answering our questions. BUT I REPEAT YOU, IF YOU CAN HELP ME, THAT HELP WOULD BE VERY APPRECIATED. (as I do with anyone asking for help in the forums, look at my posts and you should see). TIA jepetu |
01-27-2007, 12:22 | #11 (permalink) |
Member: 181633 Status: Offline Thanks Meter: 730 | The same V3 R374 using GOT v0044: 1. Repaired PDS - OK: BL: 0823 FW: ERROR NOT FOUND! FLEX: ERROR NOT FOUND! 2. Downgrade Bootcore to 07E0 with supplied backup: OK Now BL: 07E0, FW and FLEX same as above. 3. Flash a 1FF: The phone still in BL: 07E0, FW: ERROR NOT FOUND!, FLEX: ERROR NOT FOUND! Any advise please? TIA |
01-29-2007, 01:07 | #12 (permalink) |
Member: 181633 Status: Offline Thanks Meter: 730 | No one have an idea that what is hapening? I think the problem is in the "PDS Repair" function, once I used it flashing any 1FF file is useless because the phone remains in the same status (only wakeup in flash mode). I've seeing that someones are using MSS repair PDS function to recover their phones (the bad thing is that I don't have MSS). I think the repair PDS function in GOT is not fully working yet. Still waiting for a GOT-based solution. BR to all jepetu |
Rogers Motorola V3 Unlocking problem | nabeel7 | Smart-Clip | 2 | 03-25-2005 12:24 |
Cruiser V3.20 Problem!!!! | yueyo | Cruiser Suite | 15 | 03-10-2005 19:28 |
v3 flashing problem | pusulateknik | Motorola P2k | 4 | 01-30-2005 13:53 |
Motorola V3 keypad problems, please help. | yfgreene | Motorola P2k | 0 | 01-11-2005 19:05 |
Eeprom Tools by B-Phreaks v3.0 problem | IvanG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-05-2002 11:52 |
