02-15-2007, 19:03 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Dublin Age: 44
Member: 100436 Status: Offline Thanks Meter: 57 | v3r stuck in flash mode, help ? I just flashed it with "r4515_g_08.bd.44r_pds005_lp0003_drm0101_jpjava_g_ 08_r4515_00_00_18i_se4817axxxx07b_1ff.gtc" and phone is stil the same. How do I get back to normal? BR's Patrick Last edited by Patrick; 02-15-2007 at 19:40. |
02-20-2007, 00:44 | #6 (permalink) | |
Member: 100436 Status: Offline Thanks Meter: 57 | Quote:
I will try flash 1ff after PDS repair tomorrow, which file should I use?; BR's Patrick | |
02-20-2007, 07:27 | #8 (permalink) | |
Guest
Posts: n/a
Member: | Quote:
Also there was Chinese New Year and we spend time with family travel around china. There is Andres here who can help you also and he answer to your question in other thread. What support you need? Can you be more specific? Are you reseller or enduser? Best Regards, Manole | |
02-20-2007, 15:18 | #10 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Delhi
Member: 138575 Status: Offline Thanks Meter: 58 | Quote:
A SOLUTION PLEASE, AT THE EARLIEST. | |
02-28-2007, 03:42 | #11 (permalink) | |
Product Supporter Join Date: Nov 2006
Member: 394070 Status: Offline Thanks Meter: 14 | Quote:
Released GOT_MOTO v0046 - Added support for flashing original Motorola SBF files - Added info about major bootloader supported in SHX, SBF, GTC files - Added info about bootloader version in phone when flashing - Added warning message when major bootloader from flash file is lower than bootloader in connected phone for flashing - Improvements in flashing communications and flash file handling - Added phone detection when Default Connection is set to Mass Memory Storage - Automaticaly switch phones from Mass Memory Storage to Modem connection - Completely changed Easy Skip TP unlock method for POG 3G models (now should work on new E1070 phones) - Added function to set Subsidy code to 00000000 on unlocked phones (usefull before flash 1FF file and not know if file have network locked flex) - Added Easy Skip TP unlock support for C390 with bootloader 08.26 - Added Repair PDS support for C390 (R368_G) - Added Easy Skip TP unlock support for V3i(R4441D_G) with bootloader up to 0A.30 - Corrected Easy Skip TP unlock for following LTE based models: L2, L6, V19x, U6, V557 | |
02-28-2007, 03:44 | #12 (permalink) | |
There is 2 kind of V3r: R4515 and R3443U2 Try with R3443U2_G 1FF file. | |
02-28-2007, 03:53 | #13 (permalink) | |
Jus look here: V3: R374_G V3b: R37AV3_G V3i: R479_G ,R4441D_G, R47A_G, R3443H3_G V3r: R4515_G, R3443U2_G, R3443U5_G L2: R3511_G, R3517_G, L6: R3511_G, R3517_G, R3443H1_G L7: R4513_G, R44419_G, R4517_G So, use your brain and you wil be able to repair phones! | |
02-28-2007, 10:59 | #14 (permalink) | |
Yes, I checked before unlocking. I had to bring the phone to a service center, they had it back running in 3 hours for me under warranty. They said they changed the "Logic board" but I think they where talking crap. Anyway I got the phone back then unlocked it no problem and delivered it to my customer. Thank you for the massive improvements you've added to GOT today. BR's Patrick | |
03-01-2007, 05:37 | #15 (permalink) | |
PROVIDE US REPAIR FILES FOR THESE MODELS WHICH CAN SOLVE THESE PROBLEMS. IN CRACKED SOFT, SOME PEOPLE HAS ALREADY POSTED REPAIR FILES FOR THESE PHONES (V SERIES AS OF NOW), WHICH HAS SOLVED PROBLEMS. SO NOW USE YOUR BRAIN AND EXPERTISE AND GIVE SOLUTION. | |
V3R stuck in flash mode | winston_006 | Motorola P2k | 1 | 01-11-2008 08:52 |
v3r stuck in flash mode, help ? | Patrick | Motorola P2k | 16 | 03-19-2007 11:44 |
V550 stuck in flash mode | badh | Motorola P2k | 2 | 03-24-2006 03:53 |
V525 and V550 both stuck in flash mode | lc5829 | Motorola P2k | 2 | 09-27-2005 09:43 |
a835 Stuck In Flash Mode! - HELP! | thisnthat | Motorola P2k | 0 | 11-09-2004 22:27 |
