Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GOT (Gsm Online Tool) > GOT SEMC
Old 08-09-2007, 22:37   #1 (permalink)
Member: 236693
Sonork: 100.1603916
Question Unlock W810i CID 50 - it's possible?
Old 08-09-2007, 22:40   #2 (permalink)
Pecel's Avatar
Member: 123230
Sonork: 100.113333
Thanks Meter: 14
No it's not possible my friend
Old 08-10-2007, 00:06   #3 (permalink)
Member: 107172
Thanks Meter: 3
it is possible
yes it is possible with setool and logs,
you need to flash the phone and in setting must tick first 3 option and then tick the use server and security bypass and permanent unlock.
then just flash the phone, it will take 1 log and after flash phone is unlock.
Tested by me for 3 of them and all ok.
I did with setool but it may work same way with other softwares.
The Following User Says Thank You to saeedhex For This Useful Post:
Old 08-10-2007, 01:35   #4 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
PERMANENT UNLOCK,you did it with setool?
br
keaelite
Old 02-13-2008, 12:48   #5 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Where is tick box saying permanent unlock? Enable Alternative Security Bypass means Patch not Permenent Unlock and the fact that it cost only 1 log also points to patch unlock
DB2012
1 log = patch (if only 1 lock closed)
4 logs = Full unlock (if all 5 locks closed)
Old 02-19-2008, 14:44   #6 (permalink)
.::skybird::.'s Avatar
Member: 594884
Thanks Meter: 1,553
DB2012
thanks bro...
but i think it'll full unlock with only 1 log if its cid be change
i mean cid 50 to cid 52/49.
am i right ??
Old 02-19-2008, 14:50   #7 (permalink)
Member: 594884
Thanks Meter: 1,553
hello sir...
sir how you say that its not possible ...
is the S_E tool can't be it possible
.::skybird::.
Old 02-19-2008, 15:18   #8 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Originally Posted by .::skybird::. View Post
hello sir...
.::skybird::.
Note the date of the post!!! Posted over 6 months ago, things have changed since then
I made same mistake
Old 02-23-2008, 17:06   #9 (permalink)
Member: 594884
Thanks Meter: 1,553
have a good idea bro....
Cruiser cant unlock W810i CID 50 mony_valley Cruiser Suite 13 02-26-2010 14:51
K510i And W810i Cid 50 how unlock with java unlocker memobiles Cruiser Suite 0 10-27-2008 12:20
How to Unlock w810i cid 50 Deb Chandan SETool2 1 08-23-2008 15:45
unlock w810i cid 50 ????????? Mounir Cruiser Suite 7 11-14-2007 09:46
unlock w810i cid 50 ????????? Mounir Cruiser Suite 10 11-12-2007 17:02
Page generated in 0.18387 seconds with 9 queries
