05-12-2007, 20:15 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Jamaica
Member: 279555 Status: Offline Thanks Meter: 11 | help needed - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Error why is this i've only have this box about a month now, is it a waste of my money? help me in sorting out this please sagmaster team need help asap thanks. |
05-16-2007, 03:24 | #5 (permalink) |
Member: 279555 Status: Offline Thanks Meter: 11 | i still have a problem here. i tried to connect the box on my laptop and getting the above problem, i tried what i did when using my desktop and still same problem wierd. help please. test 3 error on my laptop |
05-16-2007, 04:55 | #6 (permalink) |
Member: 279555 Status: Offline Thanks Meter: 11 | just tried it on different computer and it works fine but i want to use it on my laptop, it use to work on it now why not any more???? help with this please. i'm loosing money by this not working for me |
05-31-2007, 06:45 | #10 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Harare, Zimbabwe/ South Africa Age: 44
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | i have repaired my box more than 20 times, hardware and software but now i dont knowhat to do, in my country i cant find atmega 32L chips what should i do? this is the error i am getting - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - ERROR: WRONG OR BAD HARDWARE! |
- Error: Device Damaged, Need Rebuild! | gilke | SCDR II | 1 | 04-16-2009 17:02 |
- error: Device damaged, need rebuild! Help me brother | alkesh02 | SCDR II | 2 | 04-16-2009 16:57 |
Error: Device Damaged, Need Rebuild | amr_ibrahim | SCDR II | 4 | 06-12-2007 00:37 |
- Error: Device Damaged, Need Rebuild! | gilke | SCDR II | 4 | 05-12-2007 19:10 |
Error: Device Damaged, Need Rebuild! | B Smith | SCDR II | 3 | 05-12-2007 14:05 |
