03-18-2008, 13:10 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Poland
Member: 320035 Status: Offline Thanks Meter: 7 | always PHONE NOT FOUND msg :/ I've got also TP adapters for SMTi with switch... from direct Your reseller... and maybe I'm to stupid to use that box :/ as far as I know I need no battery with 501 phone, just tp adapter, should I push the switch or not? I though that maybe adapter is not working so I soldered cables directly to pcb and still NO PHONE FOUND, I tried with and without "force HS device", I'm 100% sure that cables were soldered ok... should the phones light turn on or not? no 401 pcb I destroyed one TP so lets forget about this one, but what about that 501ci? I'm newbee in sagems so maybe I'm doing something wrong? I unlocked only two sagems so far on this box but everything was fine... can be some device prboblems if I've got jaf and vygis on that same PC? |
03-18-2008, 13:24 | #2 (permalink) |
Member: 320035 Status: Offline Thanks Meter: 7 | one more thing, before I destoryed TP in that 401 I wanted to use TP adapter, after connecting everythng and pushing teh switch button leds on pcb did turn on but no phone was still found, but in 501ci after connecting via tp adapter and pushing the switch there was no light... in both cases I did not use battery... nokia charger should be always plugged, right? |
03-18-2008, 14:02 | #3 (permalink) |
Member: 320035 Status: Offline Thanks Meter: 7 | ok, I soldered all wires (I read before on this forum that for 501ci I need only RX TX and GND)! I connected LCD flex! and powered phone but connecting ON button! and heres the log: Found Phone, Phone Info: - Phone Type :my501Ci - Phone FW :LI5,IL: 031106 1410 - Phone HT C 2C 05 - Phone IMEI :359241005445322 - Phone Code :0000 (inactive) - Prod. Code :252752287 - Board Type :m62+ - NOR Flash ID :0001 227E 2223 2201 - Chip [0] :AMD S29GL512NH/L 512Mbit Get Code from server ...Success! - Net Lo code :19612515-77 - Net Hi code :08749267-77 - Connect phone ...Ok! - Clear Net Code...Success! I did NOT use force HD device! |
03-30-2008, 14:38 | #7 (permalink) |
No Life Poster Join Date: Jul 2005 Location: TUNISIA Age: 44
Member: 160204 Status: Offline Sonork: 100.113150 Thanks Meter: 2,843 | @Kvas Phone should be Powered On , the wires that solder it if complete TP are 8 that mean include the Vbat wire so no need for bat , Power on Phone Detect then Read Code , phone must be detected , if Phone detected & always show error then you can use only 3 wires "Tx,Rx & Gnd" if with bat no need for Vbat 4th wire it's your choice then use "Forced Hs Device" for new cpu phones . |
Please help! V3xx unlock with Smart TP cable always phone not found! | smartmod.de | Smart-Clip | 2 | 11-22-2008 02:10 |
LGU8290 always Phone not found | Abzal | FuriousGold | 7 | 04-16-2008 13:30 |
== Can't Unlock Lg-u8290... Always Phone Not Found == | *Diablo* | NSPRO | 6 | 03-13-2007 14:04 |
myx-6 : phone not found | asmodi | SagMaster Team OLD Products | 2 | 07-05-2006 18:39 |
msg.phone not found | SAM5 | SagMaster Team OLD Products | 0 | 05-31-2006 10:17 |
