03-03-2008, 15:17 | #1 (permalink) |
Insane Poster Join Date: Oct 2003
Member: 40695 Status: Offline Thanks Meter: 2 | my 5 3 on virgin tp error even tried forced any help Found Phone, Phone Info: - Phone Type :myC5-3 - Phone FW :LA5,8K: 310807 1651 - Phone HT :04 20 05 - Phone IMEI :352179017143070 - Phone Code :0000 (inactive) - Prod. Code :253006209 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit |
03-04-2008, 11:07 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | Quote:
box: smti if new board direct unlock, no tp, only one log try with or without "forced hs device" if old board connect tp like on smti support here is another pic if you don't see on support image clearly | |
03-04-2008, 11:21 | #6 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | i have that test point but it wont connect still phone not found .i think there is a problem with the phone.but this a brandnew phone & it charges also when i connect a charger br |
03-04-2008, 11:35 | #7 (permalink) |
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | phone data must be read from phone direct with cable, no tp connected if you say your cable is good and you use last version of software 13.26, then it must me somethig wrong with your phone try with another phone, exactly same model, if you have one |
03-04-2008, 15:13 | #11 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Enschede, The Netherlands Age: 41
Member: 8594 Status: Offline Thanks Meter: 13 | With v13.27 all i get is " - MSG: CHECK TP!" after pressing read code. Used to unlock this version with forced hs device before. Connecting TP doesn't work for this version. Found Phone, Phone Info: - Phone Type :myC5-3 - Phone FW :LA5,8K: 130906 1056 - Phone HT :E4 25 05 - Phone IMEI :352179016538866 - Phone Code :0000 (active) - Prod. Code :252877810 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit |
03-04-2008, 20:01 | #13 (permalink) |
Member: 8594 Status: Offline Thanks Meter: 13 | After a couple of times "- ERROR: OPERATION FAIL, TRY ONCE MORE!" it worked in forced hs device mode, the phone is unlocked now. Thanks for the quick bug fix! |
03-05-2008, 11:06 | #14 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Bradford, West Yorkshire, UK
Member: 373231 Status: Offline Thanks Meter: 5 | I have a slightly different problem with myc5-3 using 13.28 Three handsets on Virgin network UK, all identical, brand new, first time out of the box and using a full battery (have also tried with power connector) First two handsets unlock perfectly on the first try. With the third handset: phone reads ok selected Forced HS same as the others press Read Code, see "REMOVE BATTERY.." prompt, remove battery and insert again, click Yes POWER ON PHONE ...Fail! Tried many times, exactly the same problem every time... any ideas? Found Phone, Phone Info: - Phone Type :myC5-3 - Phone FW :LA5,8K: 310807 1651 - Phone HT :04 20 05 - Phone IMEI :35217901701***x - Phone Code :0000 (active) - Prod. Code :253006209 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit |
03-05-2008, 13:24 | #15 (permalink) |
Freak Poster Join Date: May 2004 Location: morocco Age: 52
Member: 65817 Status: Offline Thanks Meter: 12 | i have same problem :using v 13.28 ***************************************** Detect Phone: Found Phone, Phone Info: - Phone Type :myC5-3 - Phone FW :LA5,8M: 301106 1503 - Phone HT 1 20 05 - Phone IMEI :352179014304832 - Phone Code :0000 (inactive) - Prod. Code :252867463 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit ***************************************** Read Code: POWER ON PHONE ...Fail! ***************************************** - Programm Close 05/03/2008 12:15:39 ***************************************** please fix this bug |
.::iPhone "device is not eligible, 3194 error" while trying to Restore below 4.3.5::. | .::iRizwan::. | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 02-10-2010 16:32 |
check tp,s even tp r ok | B Smith | SMTi | 1 | 09-17-2009 06:52 |
I tried to unlock my c25 5.3 with wrong software. Could somebody help me? | Vilsa | x1x to x45/x50 | 1 | 08-11-2000 11:30 |
