Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 03-02-2013, 12:55   #1 (permalink)
Member: 236764
Thanks Meter: 12
jovy re-7500 problem with lap top motherboard
hello all
i have jovy re-7500 and problem with siemens, asus motherboard ...
on 150c motherboard is bent, i use pcb support motherboard from jovy but not good solution !!
how to fix this problem ?
Old 03-02-2013, 13:04   #2 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
READ MORE AS EXAMPLE..
http://forum.gsmhosting.com/vbb/f404...9/#post4704182
Old 03-02-2013, 13:22   #3 (permalink)
Member: 236764
Thanks Meter: 12
I read it long ago ....If there is a topic that is related to my problem I ask that you give me a link where it is written!
best Regards
Old 03-04-2013, 18:02   #4 (permalink)
Member: 437621
Thanks Meter: 19
The warpage is caused by direct heating to one location where other places on the board are not heated. The RE7500 lower heaters are not large enough to heat entire board. RE8500 has sufficient size and with lower power on upper heater the warpage should not happen. On boards where this is an issue there should be extra preheat time.
Old 07-19-2013, 07:25   #5 (permalink)
Member: 63457
Thanks Meter: 26
Hey Borjan , do BT Heater preheat in fast reflow up to 145c 150c then reflow position , this is just BT Heater , then do Fast reflow UPHeater until the temperature rise to 225-230 leadfree , 185-195 leaded.... no Bend
Page generated in 0.12504 seconds with 8 queries
