Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ultimate-Sam
Old 09-14-2008, 18:52   #1 (permalink)
Member: 250251
g600 imei-after code #*7337#
is it possible to correct memi on samsung g600 after bad unlock with ultimate sam
Old 09-15-2008, 12:49   #2 (permalink)
F C
F C's Avatar
Member: 6486
Sonork: 100.79846
Thanks Meter: 350
oh come on , ultimate sam has nothing to do wid imei , it cant make it bad unlock , if u have rec fone already in dat stage is some thing diff.
ultimate sam cant kill or make imei bad , any samsung fone!
br,
Gohar
Old 09-15-2008, 12:57   #3 (permalink)
.:Spitfire:.'s Avatar
Member: 261666
Sonork: 109.896
Thanks Meter: 780
Come on!. have you used the #*7337# code?? this code wipes o0ut the eeprom, while Ultimate-sam never ever has reset the imei. WE have unlocked more than 100s of new and older G600's never ever any imei corrupt is been reported before.
wbr
Old 09-15-2008, 15:20   #4 (permalink)
Member: 190274
Thanks Meter: 47
samsung j600e imei set to 00000000000 after i flash it please some can help me to write the original imei thanks you.
Old 09-15-2008, 16:30   #5 (permalink)
Member: 177834
Thanks Meter: 1,800
check this out
http://forum.gsmhosting.com/vbb/show...51&postcount=1
Old 09-24-2008, 15:09   #6 (permalink)
Member: 250251
I did not do this with ultimate sam the phone was like this when it came to me to be unlocked I think the person who owned the phone tryed some code and it changed the numbers all to 000000000000.
so this is not caued by ultimate sam
just though i should clear this up
Old 09-26-2008, 10:39   #7 (permalink)
gsm_zone's Avatar
Member: 347619
Thanks Meter: 78
hahah
first you start a topic with this name
and then you say this
Old 09-26-2008, 15:44   #8 (permalink)
Member: 177834
Thanks Meter: 1,800
hes right but he didnt explain himself well
he meant " is it possible to correct imei on samsung g600 with ultimate sam after bad unlock using code #*7337# "
Old 09-27-2008, 01:47   #9 (permalink)
irfanmajeed's Avatar
Member: 594068
Sonork: 100.1574613
Thanks Meter: 121
good expilication from br imeimate so answer this and close the topic
wbr
Old 05-17-2014, 20:01   #10 (permalink)
Member: 518427
Thanks Meter: 5
he is write #*7337# code in some samsung mobile gives imei to 000000000000000
so please use this code at your own risk...................
i have tried in samsung d780
Old 05-17-2014, 20:02   #11 (permalink)
Member: 518427
Thanks Meter: 5
experts should give reply on this code............
g600 imei all 0000000000000 GONDOLF UST Pro II 26 10-28-2008 16:55
G600 imei all zero's after entering code. mykaloen Samsung Hardware Repair 6 08-05-2008 18:43
After flash of samsung g600 imei changed damiankrzyz HWK 8 12-05-2007 01:37
G600 Imei 000000000000000 fanbang NSPRO 42 11-06-2007 21:42
G600 IMEI REPAIR? Elco..... Tomelli NSPRO 0 10-23-2007 14:33
Page generated in 0.19885 seconds with 9 queries
