05-31-2008, 15:56 | #16 (permalink) | |
Insane Poster Join Date: Oct 2005 Location: netherlands Age: 61
Member: 187801 Status: Offline Thanks Meter: 6 | Quote:
i,m happy whith new clip and new and good updates 5 or 6 differend foons work fine .. | |
The Following User Says Thank You to gsmrat For This Useful Post: |
01-10-2009, 00:06 | #18 (permalink) |
Registered User Join Date: Dec 2002 Location: The Netherlands Age: 41
Member: 19168 Status: Offline Thanks Meter: 55 | @zsharif80, download the latest software from www.gsmkingdom.nl install it. this software will be installed in your program files directory under name ultimate-sam inside this, you will find also the qualcomm drivers, turn your u900 on without sim, insert this code: *#782872# you will get a confirmation popup. Do NOT confirm it and let the phone stay in that mode. now insert your directly connected usb cable from pc to phone. when the drivers are asked, choose them manually from the ultimate sam folder. You will have to install 2 diffrent drivers. Qualcomm modem en qualcomm serial port. now open your program, choose (u700-or newer) and press unlock. wait about a munite and viola! you phone will be successfully unlocked. good luck and best regards, GsmKingdom Last edited by to_deal_with; 01-10-2009 at 23:09. |
05-07-2009, 22:18 | #22 (permalink) |
Insane Poster Join Date: Sep 2003 Location: UK Age: 70
Member: 38731 Status: Offline Thanks Meter: 0 | Where has www.ultimate-sam.com gone.. There are no pages installed on the site. Where is the update server located? |
06-01-2009, 09:43 | #24 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | The drivers are in the folder C:\Program Files\Ultimate-Sam\Ultimate-Sam\drivers\ultimate-sam Driver\UsbDriver.exe Install this before you connect the cable(Ultimate-Sam cable) to pc Then connect the cable ,let install the drivers and connect the clip. Voila |
08-07-2009, 12:42 | #25 (permalink) |
Freak Poster Join Date: May 2009 Location: rumania
Member: 1025102 Status: Offline Thanks Meter: 74 | Supported Models: ultimate sam clip supports approx 520 models for samsung, 80% of fones are non pc operation , plug and play unlock rest (qualcom) based are supported via server support using pc. The following below mentioned models are supported by ultimate samsung clip! A Series Standalone By Clip, No PC required: A117, A127,A436,A437,A516,A517 PC and internet connection required A411,A412,,A551,A706,A707, A708,A717,A727,A736,A737,A747,A790,A811,A812 B Series Standalone By Clip, No PC required: B100,B200,B300,B500,B510 C series Standalone By Clip, No PC required: C120, C130,C140,C148,C170,C178,C180,C188,C200,C208, C210,C218, C216, C225, C230,C208,C250, C260,C268,C300,C308,C400,C417,C420,C420L,C426,C450 ,C506,C520 D series Standalone By Clip, No PC required: D100,D307, D347, D357, D407, D410, D415, D428, D488,D500, D500E, D508, D510, D520, D550, D600,D608,D610, D710,D720, D730, D800, D807, D820, D830, D840,D880, D900,D908,D900i,D908i E series Standalone By Clip, No PC required: E116, E200, E210, E217, E250,E250D, E250v,E250orange, E300, E310, E315, E316,E317,E318, E320, E330, E335, E340, E350, E308,E360, E370, E380, E390, E400, E418, E420, E428, E480, E490, E500, E530, E560, E570,E590 E640, E650, E690, E700, E710, E715, E720, E730, E740, E750, E760, E770, E780,E790, E800, E810, E820, E830, E840, E850, E860, E870, E880, E890, E900, E910, E950 F series Standalone By Clip, No PC required: F110(ADDIDAS EDITION)F200,F210,F250,F300,F308 PC and internet connection required: F330, F338,F400,F480,F490,F490V,F500,F508,F700,F700V G Series Standalone By Clip, No PC required: G600(including newer versions) PC and internet connection required: G800,G808 I Series Standalone By Clip, No PC required: I300,I320, I300x, I450 I505, I600, I607,I617,I700, I750 J Series PC and internet connection required: J200,J208 Standalone By Clip, No PC required: J600,J600E,J610,J700,J700v L Series PC and internet connection required: L170,L170V,L400,L400V,L760,L760V,L766,L768,l810 Standalone By Clip, No PC required L600,L770 M Series Standalone By Clip, No PC required: M110, M300, M320L ,M600,M610 N Series Standalone By Clip, No PC required: N700, N710 P Series Standalone By Clip, No PC required: P200, P207,P260,P300, P310, P520 Gorgio ******, P850 PC and internet connection required: P900,P906,P910,P920,P960 S Series Standalone By Clip, No PC required: S400I, S401, S401i, S410I, S500, S500i, S501,S501i,S720,S730 T Series Standalone By Clip, No PC required: T209, T219, T309, T319, ,T329 ,T429,T509, T519, T609, T619, T629, T649,T719,T729, T809,T819 PC and internet connection required: T639 U Series Standalone By Clip, No PC required: U100, U108, U300, U308, U600, U600B,U608 PC and internet connection required U700/U700v,U900,U900V X serries Standalone By Clip, No PC required: X100, X105, X120, X138,X140, X150, X156, X160, X160B, X200, X210, X300, X460, X461, X466, X475, X478, X480, X481, X486, X490, X495, X497, X500, X507,X510,X520,X530, X540, X550,X566 X600,X610, X620, X630, X636, X640, X650, X658, X660, X670, X680, X680n, X700, X770, X800, X810, X820,X828 X830, X830n, X836,X900 Z serries(3G qualcomm by Software with Original USB cable) PC and internet connection required: Z100,Z105,Z107,Z110,Z140,Z150,Z170,Z230,Z240,Z300, Z330,Z350,Z360,Z400,Z400v,Z500,Z520,Z540,Z550,Z560 , Z600,Z620,Z700,Z710,Z720,ZM60,Zv10,ZV30,ZV40,ZV50, ZV60 ,ZX10,ZX20. |
08-25-2009, 00:27 | #27 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | Quote:
plz download from here . http://forum.gsmhosting.com/vbb/showthread.php?t=812454 br, Gohar | |
10-18-2009, 13:58 | #28 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1003206 Status: Offline Thanks Meter: 0 | M110 unlock with Ultimate sam won't work. He does everything it needs te ben done. But when you put other sim in, he asks voor networdk code. Could someone tell me how to unlock the M110 Vodafone dutch? Thnx. |
Ultimate-sam v4.20 released, Fixed major bugs on Unlocking/unfreezing | .:Spitfire:. | Ultimate-Sam | 35 | 06-21-2009 23:44 |
Ultimate-sam v2.12 released. Corrected some bugs on C450 Telfort | .:Spitfire:. | Service Products News & Updates | 0 | 09-29-2008 14:22 |
The Best SW Versoins for 6280-88 spansion-unlock!!! | zeljko_c | BB5BOX | 7 | 12-06-2007 17:16 |
What is the best LG tool for flash/repair and unlock? | robbie | LG | 28 | 12-19-2005 00:29 |
