Panasonic Panasonic-News... |
09-26-2003, 21:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Africa
Member: 8843 Status: Offline Thanks Meter: 117 | "GD55 SIM MEP Lock Failed" Solution anybody with a solution and is the code correct? Last edited by Spalato; 10-17-2003 at 22:27. |
09-27-2003, 05:05 | #3 (permalink) |
Member: 8843 Status: Offline Thanks Meter: 117 | hi there. "I think you have wrong unlock code" 1. i am very greatfull to have got the code from this m8. "ask the person you got the code from" 2. i am not disputting that his code is correct or wrong but am merely asking just in case i wrote it down wrongly or else. 3. I did ask the person in PM as his suggestion but still waiting for the response. "you did pay for the code did'nt you !!!" 3. i did not pay for the code but was kindly given the code. so what is the way forward? |
10-17-2003, 22:12 | #7 (permalink) |
Junior Member Join Date: May 2003
Member: 27892 Status: Offline Thanks Meter: 0 | Datalife the code is correct but i have.. same problem, I dont know if the code calc is correct or if there is another way to enter code, As when i put code in it says done but then says sim mep lock failed and insert sim same as you. Did you get yours unlocked or did you flash it? |
10-18-2003, 00:09 | #10 (permalink) |
Freak Poster Join Date: Jan 2003 Location: inside apple products
Member: 20366 Status: Offline Thanks Meter: 10 | use **00032* and then **00012* all will be ok trust me done around a hundred this way always unlock for me just make sure to turn phone off after second code then back on |
10-18-2003, 00:16 | #11 (permalink) |
Member: 27892 Status: Offline Thanks Meter: 0 | Are there different codes as i have been given the same code by 3 people but then someone posted the nck code as different, I have had to flash the phone now as it said blocked after a few attempts at the **00012* but i still want to know where i went wrong. Thanks Darren |
10-19-2003, 10:15 | #12 (permalink) |
Major Poster Join Date: Jun 2002 Location: *** ISLAND ( BALI ) Age: 48
Member: 13140 Status: Offline Thanks Meter: 0 | see my post at gd 55 display problem and use that software, flash it and you will solve your problem and dont forget to charge you batt full please report |
10-20-2003, 00:55 | #14 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Minsk Russia
Member: 5569 Status: Offline Thanks Meter: 10 | i think i think i can change new code and send you for calc. original code [sure you cant do it] may be it in game funny bcs not only you have sw it [i think it and sure you can flashing again for come back to original code.....] regards Own |
lLG 5300 I-"SIM MEP LOCK FAILED" -AFTER UNLOCK -SAME ERROR | zonetrichur | Multi-Box | 6 | 09-25-2006 18:57 |
panasonic eb-sc3 "SIM MEP lock failed" | guty | Phone Unlocking Codes & Maps | 4 | 07-27-2006 17:05 |
Gd55 get "sim mep lock failed"!.. | yaren | Panasonic | 6 | 10-14-2004 09:44 |
LG-G5300 shows "SIM MEP LOCK failed". how to unlock it ? | the_frightener | LG | 0 | 01-09-2004 08:39 |
