Panasonic Panasonic-News... |
10-16-2003, 19:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | gd68 restart 3 time when power on gd 68 have strange problem. when power on, phone on then off this is three time on and off and off. this is hw or sw problem ? what is solution for this problem ? thanks in advance. |
01-29-2004, 20:29 | #4 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: IN CASTLE Age: 46
Member: 3925 Status: Offline Thanks Meter: 22 | hi man not work. allways make outgoing call restarting. how resolve this is problem?? thank you Quote:
03-01-2004, 22:55 | #6 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | Quote:
hi i got same problem , how did u solve it mp3hot | |
03-15-2004, 03:01 | #7 (permalink) |
Freak Poster Join Date: Jan 2003 Location: hell (gsm bussines) Age: 49
Member: 19875 Status: Offline Thanks Meter: 3 | work 1000% Hello Guys. I don't know if it is 100% working but i'm sure 99.9999% it's working tested on gd-68 and sharp gx10 OPEN THE PHONE(JUST A SIMPLE CLIP) REMOVE THE BACKUP BATTERY INSIDE THE PHONE(UPPER LCD) FOR >10SEC, PUT IT BACK AND.............. FOR ME IT WORKS EVERY TIME |
03-16-2004, 23:43 | #9 (permalink) | |
Member: 19875 Status: Offline Thanks Meter: 3 | Quote:
M8 u don't see the issue Removing the battery(backup) is the same thing as memory reset with th panasonic program but much easy and the PA resolder might not solve the problem.I tried the Pa resolder and no results but considering the fact that the battery is on the other side............ any way I need to thank u for sharing the "memory reset " trick. I`ve done it with battery removal | |
N73 Auto restart when powered on | .:==di@bila==:. | Nokia Hardware & Hardware Repair | 8 | 12-12-2010 09:31 |
V500 only restarted when power on | denard | Ultima Box Light | 1 | 03-13-2008 00:53 |
help BIRD S788 RESTART WHEN POWER ON | RCOBBA | Infinity-Box | 1 | 03-01-2006 21:00 |
nokia 3310 hang and restart when power on | barthosyn | Nokia Hardware & Hardware Repair | 12 | 01-05-2006 22:48 |
solution 4 t610 when powered on blue screen 4 only 3 seconds | MichieMax | Sony Ericsson Hardware Repair | 7 | 10-15-2004 17:51 |
