Panasonic Panasonic-News... |
09-01-2003, 06:44 | #1 (permalink) |
Junior Member Join Date: Sep 2003 Location: Miami,FL Age: 58
Member: 38106 Status: Offline Thanks Meter: 0 | help GU87 i press the configuration i get on the screen :ring up at 07092023221 and the serial connection OK. when i press the unlock i see on the screen power on when i press power ,i get time out, i must try this a million times and no code. so i can't unlock my cell .I live in miami FL and the cell is lock in to AT&A. |
09-01-2003, 08:04 | #3 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Shenzhen, China
Member: 7911 Status: Offline Thanks Meter: 7 | What firmware version do you have in your phone? Turn the power off, then back on again. When the phone starts to display "Searching for network", enter *#9999# - on the screen that appears, the top line will say something like: 34FDGAD87A38-38 The number after "GAD87" is the firmware version number - in this case A38. If this is over A22 then the cracked unlocker won't work. You can either find someone with a newer unlocker or downgrade the firmware, unlock, then upgrade it again. If the firmware version is OK and you are using a data cable (rather than a flashing/unlock cable) then try insulating pins 4 and 10 on the phone and trying again. |
09-02-2003, 15:44 | #9 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | well the codes will work surely....and if u dont know what u are doing then dont play with your phone..... Panasonics are not for newbies...if u dont want to make ur phone a dead toy then dont play with it ...take it to an experienced unlocker instead...... WBR Syed |
11-03-2003, 17:06 | #11 (permalink) |
Member: 38106 Status: Offline Thanks Meter: 0 | I need to unlock my panasonic cell I live in miami FL [email protected] |
help [ANSWERED] | mariusgsm76 | Nano-Box | 2 | 04-01-2010 11:33 |
help gu87 | mohammadmouazen | Panasonic | 2 | 07-23-2004 21:14 |
gu87 help | linksr | Panasonic | 1 | 03-13-2004 14:19 |
help on GU87 ATT | panpan | Panasonic | 2 | 07-25-2003 10:40 |
Need Some Help on Unlocking AT&T GU87 | cwai02 | Panasonic | 7 | 07-11-2003 00:48 |
