Panasonic Panasonic-News... |
11-13-2004, 00:20 | #1 (permalink) |
Insane Poster Join Date: Oct 2003
Member: 41929 Status: Offline Thanks Meter: 0 | Need GD88 language pack file GAD87A53 Thanks |
11-14-2004, 22:32 | #3 (permalink) |
Member: 41929 Status: Offline Thanks Meter: 0 | thanks, but that language pack only has english as the only option. Is there another one that has all four languages in it? Also, the first link is the only one that is working. The other 2 below it show "unavailable pages". |
11-15-2004, 09:18 | #4 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Romania Age: 48
Member: 59869 Status: Offline Thanks Meter: 132 | Change or select languages Open CB2000 Connect cable to the phone. (make sure isolate pins 4 and 10 on the phone) Select the COM1 which the cable located Press the "Handset Power", then turn on the power of the phone You should see "TEST MODE ON" on the LCD Click "Read Handset", make sure "Security Lock State" is Unlocked. (It is what we said: EEPROM Unlock) Then you can click the Languages First, click the Clear bottom, all languages will be disabled. Second, click the C bottom, you will see all languages will be selected. (depends on which language pack you have been flashed into the phone) http://gd87bios.pagesonline.net/ sorry to see that www.spunlock.com is no longer available .... do a search on this forum and you will find answers on all your quetions BR, Oblio |
11-15-2004, 09:55 | #5 (permalink) |
Member: 41929 Status: Offline Thanks Meter: 0 | Great! Thanks for your help!!!! Just one question, is there a limit to the ammount of languages I can put on the phone? Cause I see in the list that they are all new, and when I try to put spanish, portuges, and french into my phone from CB2000's list, it is unable to flash it in. Even when I deleted all the rest of the languages in the phone and started from new. Is there a way I can get the rest of the languages in CB2000's list enabled? Last edited by Delsole; 11-15-2004 at 21:32. |
Need Indonesia language pack file for BenQ siemens E 61 | ubuntu | Infinity-Box | 3 | 03-01-2008 06:08 |
A1200 language pack file badly needed. | .:==di@bila==:. | Motorola P2k | 0 | 12-14-2007 17:12 |
Needed V3i language pack/ flash files / russian/arabic | manni_124 | Motorola P2k | 3 | 02-01-2006 19:49 |
a50 language pack file please? | gsmsalers | x1x to x45/x50 | 0 | 03-09-2004 03:49 |
X35 Language Pack file format | hoangnx | x1x to x45/x50 | 7 | 01-23-2002 21:48 |
