Panasonic Panasonic-News... |
08-11-2004, 15:53 | #1 (permalink) |
Junior Member Join Date: Apr 2004 Age: 39
Member: 63217 Status: Offline Thanks Meter: 0 | panasonic GD87 frontal display problem |
09-05-2004, 10:19 | #4 (permalink) |
Junior Member Join Date: Sep 2004 Age: 57
Member: 80331 Status: Offline Thanks Meter: 0 | NO NO NO its simple.....it sounds like you havent put the little magnet in the new case, check your old case and you should find it in the inside of the keypad housing section. The front display will not work with out it and you will also find that the main screen remains lit even when closed. This magnet is a switch which diverts power from one screen to another when either open or closed ie. when open power goes to the main screen and when shut it diverts the power to the small lcd screen. You need this magnet for the phone to work properly, with out it your battery will discharge very fast as power is costantly being feed to the main screen. Last edited by jim67; 09-06-2004 at 07:53. |
***panasonic gd87 problem*** | infogsm | Panasonic | 8 | 12-17-2004 19:43 |
GD87 display problem | Cat10 | Panasonic | 1 | 12-04-2004 13:54 |
Panasonic GD87 Dual Sim problem | saznat | Panasonic | 0 | 10-26-2004 23:10 |
I have panasonic gd87 and big problem | ZetMen | Panasonic | 6 | 08-13-2003 00:29 |
Display problem in Panasonic GD 90 | dheeraj | Panasonic | 0 | 08-03-2002 16:39 |
