Panasonic Panasonic-News... |
02-26-2003, 14:27 | #1 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Kiev, Ukraine Age: 46
Member: 6852 Status: Offline Thanks Meter: 4 | Repair DEAD Panasonic - free solution solution for phone with BGA or no BGA chip you need : - 1 dead phone and 1 worked phone - hot air station and soldering station - PC with cable - software use WinMoDo with language pack Steps : - desolder from bad phone flash chip - desolder from good phone flash chip - solder in BAD phone works flash chip - connect good phone with cable to PC - run WinMoDo with GANG mode - starting upload - when you see in LCD : Flash loader - disconnect cable from phone - in display you see Flash loader and phone frezee - phone in FLASHING MODE !!!! - YOU NEED DESOLDERING FLASH CHIP FROM WORKED, POWERED AND FREEZED in flash mode PHONE !!!!!!!! CAREFULY !!!!!!!!!!!!! - DESOLDERING GOOD FLASH CHIP from BAD phone (phone still avaible in flash mode) - SOLDER BAD FLASH CHIP in BAD PHONE - PHONE STILL in FLASH MODE - connect phone with cable to computer - press OK - you see uploading process - erasing 7-10 minute and flashing - :-)) smile P.S. use Winmodo with option writing BOOT, MAIN and LP flash ENJOY P.S. tested and approved by m.com - GD35, 92, 93, 95 ATTENTION!!! AUTOR TAKES NO RESPONCIBILITY FOR DAMAGED PHONES! ATTENTION!!! my expirements - 6 bad flash chip - only way reprogram on LabTools 148C or 48 but i repaired over 50 phones. Last edited by m.com; 03-01-2003 at 08:08. |
03-01-2003, 07:29 | #5 (permalink) |
Member: 6852 Status: Offline Thanks Meter: 4 | yes. is BGA. P.S. when i repair dead Panasonic phone - i can with smile solder/desolder 200 item BGA chip, and NO SMILE, NO ..... with TSOP chip - examply GD93. |
03-03-2003, 09:38 | #11 (permalink) |
Member: 6852 Status: Offline Thanks Meter: 4 | for repair Panasonic need : Hardware : - hot air station - solder iron - PC - PC cable for Panasonic - microscope (optional) - good charging battery Software : - WinMoDo 3.09 - flash file - main and language P.S. when i working with phone i solder contact battery to plate. i use no original battery, but for Sony J5 is very good. |
03-03-2003, 10:41 | #13 (permalink) |
Member: 6852 Status: Offline Thanks Meter: 4 | WARNING !!!! if you lost original flash chip , you lost eeprom area !!!!!!!!!!!! and when you solder another flash chip, repeat repair procedure and power on phone - phone no powered !!! |
How I can repair my Panasonic GD95 | Freshbol | Multi-Box | 2 | 04-11-2007 20:48 |
UPDATE 27 Apr 2006: Panasonic X500 repair dead boot zone added | InfinitySupport | Infinity-Box | 30 | 05-02-2006 11:12 |
REPAIR SOLUTION for DEAD Panasonic phone | m.com | Panasonic | 96 | 09-23-2005 21:09 |
JTAG Full Device for repair ACER, Panasonic,LG,Haer,VK Mobile & other !!! | MaxiGroup | Main Sales Section | 2 | 05-09-2004 11:39 |
Panasonic Free Solution for REPAIR DEAD Phones | m.com | Panasonic | 0 | 03-03-2003 13:42 |
