Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 08-11-2004, 15:53   #1 (permalink)
Member: 63217
Question panasonic GD87 frontal display problem
hi all,have a big trouble here...i have changed that "complete plastic body" of my phone(sorry my bad english,hope you all understand what i mean ),and now the frontal display(that little display which you see when the phone is closed) is not working ! I have not touched absolutely nothing (100% sure) except those plastic parts,and have no idea what's wrong.please,help me! a BIG thanx in advance
Old 08-22-2004, 15:55   #2 (permalink)
Member: 73571
Thanks Meter: 2
change the patchcord beetwen display and pcb
Old 08-22-2004, 15:55   #3 (permalink)
Member: 73571
Thanks Meter: 2
verify the pcb conector first
Old 09-05-2004, 10:19   #4 (permalink)
Member: 80331
NO NO NO its simple.....it sounds like you havent put the little magnet in the new case, check your old case and you should find it in the inside of the keypad housing section. The front display will not work with out it and you will also find that the main screen remains lit even when closed. This magnet is a switch which diverts power from one screen to another when either open or closed ie. when open power goes to the main screen and when shut it diverts the power to the small lcd screen. You need this magnet for the phone to work properly, with out it your battery will discharge very fast as power is costantly being feed to the main screen.
***panasonic gd87 problem*** infogsm Panasonic 8 12-17-2004 19:43
GD87 display problem Cat10 Panasonic 1 12-04-2004 13:54
Panasonic GD87 Dual Sim problem saznat Panasonic 0 10-26-2004 23:10
I have panasonic gd87 and big problem ZetMen Panasonic 6 08-13-2003 00:29
Display problem in Panasonic GD 90 dheeraj Panasonic 0 08-03-2002 16:39
Page generated in 0.13362 seconds with 9 queries
