08-04-2013, 11:22 | #61 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BAIA SPRIE,MM,RO Age: 59
Member: 74719 Status: Offline Sonork: paulelectro Thanks Meter: 181 | HWK Update Client v 2.2.0.0 USE LAST VERSION- ALL YOU NEED ITS HEAR, SEARCH HWK Update Client v 2.3.0.0 |
The Following User Says Thank You to paulbs For This Useful Post: |
08-04-2013, 11:33 | #62 (permalink) |
Junior Member Join Date: Jun 2006
Member: 297203 Status: Offline Thanks Meter: 0 | Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:04.08.2013 14:29:18 ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 82760 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID : A1.04-PRO1-7257FEA3426000C1 -- HWK Status : 1, DL: 0 ---------- Поиск сервера обновлений HWK... Поиск сервера обновлений HWK завершен. Подготовка подключения к серверу... Подключение к серверу... Канал обмена данными с сервером открыт. Авторизация на сервере... Ошибка аутентификации: Connection Closed Gracefully. In English the same error can the driver is updated, or UpdateClient? |
08-04-2013, 13:10 | #63 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1706213 Status: Offline Thanks Meter: 213 | Box: 1 Location: 2609 Serial: 78894 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78894 HID: 77452034436000C4, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 182.182.12.109 Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 2609 Serial: 78894 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78894 HID: 77452034436000C4, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 182.182.12.109 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 78894 NVML: OK BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 78894 LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78894 HID: 77452034436000C4, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Authentication stage error: Connection Closed Gracefully. |
The Following User Says Thank You to shahidjanu For This Useful Post: |
08-04-2013, 14:27 | #65 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Ghana Akatsi Age: 40
Member: 853308 Status: Offline Thanks Meter: 61 | Hwk update problem Box: 1 Location: 532 Serial: ***** UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn:****** HID: 70A67ECB426000C3, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 41.204.59.13 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N:242*** NVML: OK BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: ***** LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: ***** HID: 70A67ECB426000C3, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Authentication stage error: Connection Closed Gracefully. |
08-04-2013, 15:33 | #66 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | CPU: GenuineIntel Platform: Windows NT 6.1 (Build 7601 Service Pack 1) Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Users\lakgsm\Desktop C:\Users\lakgsm\AppData\Roaming\Microsoft\Windows\ Start Menu\Programs Box: 1 Location: 4417 Serial: 140xxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 140xxx HID: 40621E3A00270073, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 112.134.227.176 Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 4417 Serial: 140xxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 140493 HID: 40621E3A00270073, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 112.134.227.176 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 140xxx NVML: OK BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 140xxx LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 140xxx HID: 40621E3A00270073, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Authentication stage error: Connection Closed Gracefully. how to solve this problum |
08-05-2013, 07:28 | #67 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: Ghaziabad, India
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | Quote:
follow this... http://forum.gsmhosting.com/vbb/f311...6/#post7009460 | |
08-05-2013, 13:54 | #68 (permalink) |
Junior Member Join Date: Jul 2007 Location: MUMBAI Age: 40
Member: 544326 Status: Offline Thanks Meter: 0 | App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft Box: 1 Location: 273 Serial: 98028 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98028 HID: A8792B144160001B, HWK: A1.04-PRO1 LIC: True HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: 2 Your IP: 115.240.63.29 Support: Account Ok Something Wrong, Try to Use [Update Box] please help me thanks in advance |
09-23-2013, 12:19 | #71 (permalink) | |
09-23-2013, 13:14 | #72 (permalink) |
No Life Poster Join Date: Aug 2009 Location: India, W.B, Kolkata
Member: 1093574 Status: Offline Sonork: 100.1646163 Thanks Meter: 474 | ::::::::::: Update after 24hours Then will be try to update ............... ok Download this update client for micro hwk from google : UpdateClient(33133) OR" UpdateClient(GB-93206) Link: updateclient(gb-93206) - Download - 4shared - parvez_makmobile |
02-14-2014, 12:57 | #74 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Basarabia, Romania
Member: 174330 Status: Offline Sonork: 100.101441 Thanks Meter: 10 | same error: Code: App: UFSx (HWK) Control Panel v 2.3.0.4 by SarasSoft CPU: AuthenticAMD Platform: Windows NT 5.1 (Build 2600 Service Pack 3) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Documents and Settings\Administrator\Desktop C:\Documents and Settings\Administrator\Start Menu\Programs Last Server Update: 2014/01/09 Active Panel Version: 2.3.0.4 App: UFSx (HWK) Control Panel v 2.3.0.4 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 114 Serial: 81455 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 81455 HID: --------------, HWK: A1.04-PRO1 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: AB11 Failed: 102 Your IP: --------- Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 114 Serial: 81455 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 81455 HID: ------------, HWK: A1.04-PRO1 LIC: True Your IP: --------- Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 81455 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 81455 LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 81455 HID: -----------, HWK: A1.04-PRO1 LIC: True Authentication stage error: Connection Closed Gracefully. Internet connection error or server offline. Box: 1 Location: 114 Serial: 81455 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 81455 HID: -----------------, HWK: A1.04-PRO1 LIC: True Your IP: --------- Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 81455 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 81455 LIC5: True BOXK: 2 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 81455 HID: -----------------, HWK: A1.04-PRO1 LIC: True Authentication stage error: Connection Closed Gracefully. Internet connection error or server offline. Box: 1 Location: 114 Serial: 81455 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 81455 HID: ----------------, HWK: A1.04-PRO1 LIC: True Your IP: -------- Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 81455 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 81455 LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 81455 HID: -------------, HWK: A1.04-PRO1 LIC: True Authentication stage error: Connection Closed Gracefully. Internet connection error or server offline. |
5110 ver 5.28 lock 1,2,3,4 all closed | Bruyes | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 10-27-2000 08:28 |
How to use Nokia tool - with connection 6-7 pin or not?.. | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-20-2000 19:53 |
case closed nokia 5110 v5.28 unlocked | king76 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-08-2000 08:48 |
WE OFFER cables for connection cellular-phones to the computers | GLEBUS | Main Sales Section | 0 | 06-04-2000 19:05 |
Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-27-1999 09:36 |
