10-09-2013, 06:27 | #78 (permalink) |
No Life Poster Join Date: Mar 2012 Location: *#0011# NG
Member: 1736804 Status: Offline Sonork: @kanokh / @imeione Thanks Meter: 451 | App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 17 Serial: 72389 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 7 UFS_USB V2.6 (c) SarasSoft 2005., Sn: 72389 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Your IP: 114.130.65.28 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] Box: 1 Location: 17 Serial: 72389 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 7 UFS_USB V2.6 (c) SarasSoft 2005., Sn: 72389 LIC: True Your IP: 114.130.65.28 Support: Bad HID, Cannot Access Suport REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 72389 NVML: Ok INIT FBI Failed: 1 |
10-12-2013, 07:01 | #80 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1356821 Status: Offline Thanks Meter: 85 | please any one can help with this box i hase buy it from a frend hes has note use it for 3 years i have instald it under windows 7 professional 32 thanks for all help App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 0 Serial: 78983 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78983 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Your IP: 88.172.122.113 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] Box: 1 Location: 0 Serial: 78983 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78983 LIC: True Your IP: 88.172.122.113 Support: Bad HID, Cannot Access Suport REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 78983 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 78983 LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78983 LIC: True App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 0 Serial: 78983 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78983 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Your IP: 88.172.122.113 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] |
10-17-2013, 04:24 | #83 (permalink) |
Junior Member Join Date: Mar 2009
Member: 990302 Status: Offline Thanks Meter: 1 | Any Body please help my box ( n-Box ) App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft Box: 1 Location: 1553 Serial: 91528 Boot Id: 00 00 Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft Box: 1 Location: 1553 Serial: 91528 Boot Id: 00 00 Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] Box: 1 Location: 1553 Serial: 91528 Boot Id: 00 00 Box Login Failed Fatal LOGIN Error, Need Repair Box, Contact Distributor.. how can i fixed that,,, ( need any silution ) plzzzzzzz |
The Following User Says Thank You to harrycsz For This Useful Post: |
10-19-2013, 10:10 | #84 (permalink) |
Junior Member Join Date: Jun 2009 Location: india Age: 36
Member: 1063204 Status: Offline Sonork: mujeebbridco Thanks Meter: 0 | 16 please reinstall support suite App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 532 Serial: 90201 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 90201 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Your IP: 117.206.31.17 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] Box: 1 Location: 532 Serial: 90201 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 90201 LIC: True Your IP: 117.206.31.17 Support: Bad HID, Cannot Access Suport REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 90201 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 90201 LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 90201 LIC: True then this error ''16 please reinstall support suite'' how to solve this pro |
10-26-2013, 21:12 | #86 (permalink) |
Junior Member Join Date: Jan 2013 Age: 34
Member: 1870514 Status: Offline Thanks Meter: 0 | uninstall ur antivirus or pause protection.. then go to UFS PANEL... 1. go to HARDWARE TAB 2. SCAN BOXES 3. CHECK BOX 4. UPDATE BOX 5. again CHECK BOX 6. go to SOFTWARE TAB 7. CHECK SEVER 8. INSTALL ***problem solved*** |
10-27-2013, 10:44 | #87 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | (1) formating window some error solve... (2) after formating not solve ufs error then flash ufs & hwk box. how to flash ufs & hwk? ans:- which coming errore. error name hwk flasher search in google. note:- if not solve final solution all error. (1) change hwk internal ic.. (2) hwk internal ic conect to hwk ic flasher divice with battry (its 'a usb device). and when u conect bettry flash........... buy in market. .. |
