03-10-2009, 09:53 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Age: 51
Member: 69514 Status: Offline Thanks Meter: 66 | w362 A96.1.0.07_IndiaReliance3in1.sfl firmware with scout but flashing stopped at around 96% giving error.Now mobile is not powering on fully it just shows Flex Code DL Err? on. It is now not recognise with usb also .How should I solve this problem? Please help, First it's firmware was A96.1.0.16. |
03-10-2009, 12:02 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | What exact error message SCout flasher shows you when "flashing stopped at around 96%" ? Downgrade firmware is not recommended for any handset. ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com |
03-10-2009, 13:01 | #3 (permalink) |
Member: 69514 Status: Offline Thanks Meter: 66 | This is only firmware that was available for reliance IINDIA .I do not remember exact error message.Is there anyway to connect handset with p.c i.e test point or boot mode? |
03-10-2009, 14:35 | #5 (permalink) |
Member: 69514 Status: Offline Thanks Meter: 66 | when I try to flash with same version it shows following errors SCout 1.16. Flashing "W362(A96).alpha" on "COM37/460800" with firmware "G:\New Folder\W362 reliance\A96.1.0.07_IndiaReliance3in1.sfl"... Initiation... Press target power on... Sending download command... Sending application version... Sending unlock command... Timeout waiting for command reply Check connection between PC & phone & process stops. mobile switching on & off after few seconds .what should I do now? |
03-12-2009, 08:22 | #7 (permalink) |
Member: 69514 Status: Offline Thanks Meter: 66 | I tried with W362(A96).beta but same result.It stucks at Sending unlock command... only .Is there anyway to bypass this command? or is there any other way to flash it? |
W362 Latest Driver Qualcomm USB Driver | GuruKids | Motorola ODM | 4 | 11-14-2011 06:13 |
please need w362 cdma pinouts !!!! | mobayk | Scout | 2 | 02-12-2009 14:35 |
W362 India Firmware & Flasher Get Here! | SmartFlasher™ | Motorola ODM | 1 | 08-15-2008 06:28 |
Please w362 driver not in rapshere please | mobayk | Motorola ODM | 0 | 08-12-2008 13:49 |
W362 CDMA Calcuta DM TOOLS | simonng83 | Motorola ODM | 7 | 04-11-2008 15:07 |
