12-19-2007, 16:04 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | @all Algerian Unlockers About New Security Dct4plus IF YOU HAVE THIS PHONE AND MULTIBOX THEN PLEASE CONTACT ME IMMEDIATLY SO I CAN FIX ALL PARTIALS REMOTE ON SERVER IMMEDIATLY! BR karwos |
12-19-2007, 18:49 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: sarcelles Age: 47
Member: 161061 Status: Offline Thanks Meter: 568 | we have many phone 6.46 with probleme unlock and phone error unlocked and flashed with version 3.34 now it contact service thank for help br ziz |
12-19-2007, 19:12 | #3 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Barcelona
Member: 206476 Status: Offline Thanks Meter: 459 | Oi i have 4 phone 1110i made in india tow contact service one work perfect but locked to operator one without network after flash i am ready for all teste u need but only one msn [email protected] |
12-19-2007, 19:41 | #5 (permalink) |
Freak Poster Join Date: Jun 2006 Location: ALGERIA
Member: 288754 Status: Offline Thanks Meter: 63 | if the nokia tool v 4.0c doesn't work correctly in RH 93 v 6.46 and 3.43 with new security MCU,you(Karwos) must resolve the problem in this modul in futur update to correct bugs of most RH- 93 and others... we waiting the next big update which fixes all bugs.we appreciate any suggestions and any ideas to perfect this work with you. |
12-19-2007, 19:55 | #6 (permalink) |
Freak Poster Join Date: Dec 2007 Location: algerie
Member: 643285 Status: Offline Thanks Meter: 11 | Rh3 6.46 Unlock Succes But Product RH-93 MCU Version V 6.46 MCU Compilation Date 22-03-07 Product Manufacturer (c) NMP Phone is in: Local mode OTP IMEI 35xxxxxxxxxxxxx PPM Variant ]H HWID 0606 PRODUCT CODE 0555892 BASIC PRODUCT CODE 0551221 PRODUCTION S/N IIG545869 MODULE CODE 0203464 UEM 1328 BATTERY 85% UPP 8705 RFIC 0500 DSP P05w06.v34 LCD WIN:MYKS:04 ST7507 SIMLOCK 603020 ASIC 2 SIMLOCK Key Count 0 SIMLOCK FBUS Count 0 SIMLOCK Server Attached OK, Operation took 4 seconds Executing Post-attach procedures ================================================== =============== 1. Found product LCD Pattern settings 2. Found product ADC Channels settings 3. Calculating unlock codes #pw+ 419 127 346 763 634 +1# #pw+ 444 417 473 276 726 +2# #pw+ 302 196 731 003 306 +3# #pw+ 803 961 632 101 076 +4# #pw+ 709 260 136 764 476 +5# #pw+ 924 512 352 217 026 +6# #pw+ 435 037 660 372 143 +7# 4. Auto-RPL Backup Backing up Flash-Area RPL... OTP IMEI: 35xxxxxxxxxxxxx This function is not supported by this Product! 5. MCUSW CRC Backup Phone does not have MCUSW CRC Checking Procedure! 6. Security Code Mastercode: 6201417001 ================================================== =============== Post-attach procedures done Product RH-93 MCU Version V 6.46 MCU Compilation Date 22-03-07 Product Manufacturer KARWOS! Phone is in: Local mode OTP IMEI 35xxxxxxxxxxxxx PPM Variant ]H HWID 0606 PRODUCT CODE 0555892 BASIC PRODUCT CODE 0551221 PRODUCTION S/N IIG545869 MODULE CODE 0203464 UEM 1328 BATTERY 85% UPP 8705 RFIC 0500 DSP P05w06.v34 LCD WIN:MYKS:04 ST7507 SIMLOCK 603020 ASIC 2 SIMLOCK Key Count 0 SIMLOCK FBUS Count 0 SIMLOCK Server Attached OK, Operation took 5 seconds Executing Post-attach procedures ================================================== =============== 1. Found product LCD Pattern settings 2. Found product ADC Channels settings 3. Calculating unlock codes #pw+ 393 396 022 175 501 +1# #pw+ 444 417 473 276 726 +2# #pw+ 302 196 731 003 306 +3# #pw+ 803 961 632 101 076 +4# #pw+ 709 260 136 764 476 +5# #pw+ 405 867 531 370 777 +6# #pw+ 435 037 660 372 143 +7# 4. Auto-RPL Backup Backing up Flash-Area RPL... OTP IMEI: 35xxxxxxxxxxxxx This function is not supported by this Product! 5. MCUSW CRC Backup Phone does not have MCUSW CRC Checking Procedure! 6. Security Code Mastercode: 6201417001 ================================================== =============== Post-attach procedures done Unlock started IMEI: 35xxxxxxxxxxxxx Product: RH-93 ASIC: 2 MCU Version (V 6.46) Local mode set Unlock mode: Server Signed Simlock Profile: 80000000000100 -> Connecting to Typhoon Server... => Typhoon Server v8.3, (c) 2004-2007 KarwosGSM -> Sending Hash Request... OK -> Received hash OK -> Connection closed Writing locks... OK, Status: Opened, MCC-MNC: 00101 Repowering... Unlock finished after that phone unlocked but no network coverage |
12-19-2007, 20:32 | #7 (permalink) | |
Member: 288754 Status: Offline Thanks Meter: 63 | Quote:
12-20-2007, 13:36 | #8 (permalink) |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | The problem is in partial file. All 1200 and 1208 partials fixed already, but 1112 problem still occur pls hold until i can fix problem A.S.A.P |
12-20-2007, 14:27 | #9 (permalink) |
Freak Poster Join Date: Feb 2004 Location: ALGERIA Age: 41
Member: 53239 Status: Offline Thanks Meter: 14 | I have successful repaired one 1110i 6.46 contact service(damaged by jaf),with karwos soft(thank you for this update)and unlock it. first probleme I lost the LCD,I solved it by flashing the unlock_img+PPM+CNT. 2nd probleme no network. I think that the probleme is in partial file or write a new pm of 1110i 6.46 New Security Dct4plus. if you can send me a good PM of 1110i 6.46 new security,I will test it and I will post result. Thanks in advance... |
