01-09-2007, 20:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Tunisia Sidi Bouzid
Member: 104737 Status: Offline Thanks Meter: 76 | @ Expert only During unlocking Alcatel C550x I got this message -Screan Shot- Attached. Note: At half of procedure the P in display changet to U. What is wrong in this states? rgds |
01-09-2007, 22:47 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | i think it's a low power problem from ur usb port (or hub) try to power off ur computer (not restart) and try again with ur Multibox br <= The_Gorr => |
01-10-2007, 10:10 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Hackers hell
Member: 327309 Status: Offline Sonork: 100.54567 Thanks Meter: 177 | Need to write EEPROM and then flex it. Only after that you can unlock. But as I understood the phone is dead because you connect it through Bootmode, isn't it? So first you need to restore it and only after that - unlock. How to flash Philips in BOOT Mode ( USED FOR DEAD PHONES ) - this will help you to restore phone. |
01-10-2007, 11:21 | #4 (permalink) | |
Member: 104737 Status: Offline Thanks Meter: 76 | Quote:
First my phone is not dead, I can't connect it with sof (See Attachement). The phone not completed connecting with soft, how to write eeprom and flex. NOTE: during connection, the yello dot work and P in LCD of the box change to U. rgds | |
01-10-2007, 13:14 | #8 (permalink) |
Freak Poster Join Date: Jan 2006 Location: somewhere
Member: 227038 Status: Offline Thanks Meter: 78 | try what @the GORR said so not, try with another PC. c550x and c560x have even protocol of communication it does not matter that you select c550x or c560x. |
01-10-2007, 18:52 | #9 (permalink) |
Member: 104737 Status: Offline Thanks Meter: 76 | I Tried all possibily, different PC's, Some cables, Two version software. And nothing happened!!! But, one question at end: Why my box show in the LCD screan "P" when I open software and during process with phone it change to "U"? Two days and the set is in my hand. rgds |
01-10-2007, 20:32 | #11 (permalink) |
Member: 104737 Status: Offline Thanks Meter: 76 | Soory, I'm not ignorant in this state, I tried with philips and LG.... Phones, the box work well. But with this stipped one happened this problem. See the attachement plz. thanks to all hwo told to giving helps.. rgds |
01-10-2007, 20:38 | #12 (permalink) |
No Life Poster Join Date: May 2005 Location: in my office
Member: 145076 Status: Offline Thanks Meter: 224 | With the version 7.6 I had the same prob my box changes the P to U but with the version 7.7 she it makes the same thing also, I have change the model of the C550 to C560 my box walks normal, what I think Prob of soft tried to uninst and install again, good luck |
01-11-2007, 09:16 | #13 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | if u see carfully ur attachement u'll understund that ur box loose communication with pc did u tried another pc !! br <= The_Gorr => |
01-11-2007, 11:27 | #14 (permalink) | |
br. th-gorr | |
