lg 342i reboot-doubts--please help - fixed ;) I HAVE A LG 342I REBOOT PROBLEM.I DOWNLOADED TWO FILES FROM SUPPORT. 1.L342i_P40FL_V10h_356186002255328_full(16384KB)bi n file FROM FLASH FULL SUPPORT AREA 2.L342iP40-07-V10a-250-01 JUL 18 2005_01.bif(5.71MB) FILE FROM FLASH OG AREA MY DOUBT IS HOW FLASH USING ABOVE FILES IN MULTIBOX? I FLASHED USING FIRST FILE (16384KB) IN VYGIS-STILL SET IN REBOOT.I DONT KNOW HOW FLASH USING MULTIBOX. THANK U |
2. Start the LG2G tool of the latest version. One socket will began blinking at the same moment - this must be one called "UNI". 3. Go to bookmark "settings" - and select correct com port. In my case multi-box port is 3 ( do not change it ), phone com port is 6. ( is very important to select correct phone com port - in other case you will get always error in connection ) http://www.multi-box.net/img/docs/lg2g_2.gif 4. Go back to main bookmark and select correct phone model and working speed. http://www.multi-box.net/img/docs/lg2g_1.gif 5. Connect your phone to cable and then plug the cable to blinking socket "UNi" ( phone must be off ). Press "connect" botton and then press the botton +vcc 5V on box. http://www.multi-box.net/img/docs/lg2g_3.gif You will see readed info from your phone: IMEI, phone version and model. ( sometimes software don't show you version and model - don't worry - you can continue your work ) If you get error: ERROR - Phone don't answer RF - that mean that selected working speed is not good for this model - try to select slower speed. http://www.multi-box.net/img/docs/lg2g_4.gif 5. Select flash files 1 and 2. First flash file is codedata, second - AlchemyData. http://www.multi-box.net/img/docs/lg2g_5.gif 6. Press "write flash" botton. http://www.multi-box.net/img/docs/lg2g_6.gif Flashing progress starts. Now you can take a cup of tea. 7. DONE http://www.multi-box.net/img/docs/lg2g_7.gif Press "disconnect" botton on software. Disconect the phone from box, cable. Reconect the battery and swith on the phone. Phone working - firmware changed! |
I GOT TWO FLASH FILES 1.L342i_P40FL_V10h_356186002255328_full(16384KB)bi n file FROM FLASH FULL SUPPORT AREA 2.L342iP40-07-V10a-250-01 JUL 18 2005_01.bif(5.71MB) FILE FROM FLASH OG AREA WHICH FILES R DOWNLOAD FROM SUPPORT TO FLASH.IN WINDOW TWO FILES NEED TO FLASH.THAT IS FLASH 1 AND FLASH2.MY DOUBT IS WHICH FILES R SELECT HERE? THANK U |
for LG342i reboot if you flash the phone all version stay reboot, just flash it C3320 flash file and your phone will work again |
I DID AS U SAID--SET OK--THANK U VERY MUCH |
