02-17-2007, 16:26 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | lg 342i reboot-doubts--please help - fixed ;) 1.L342i_P40FL_V10h_356186002255328_full(16384KB)bi n file FROM FLASH FULL SUPPORT AREA 2.L342iP40-07-V10a-250-01 JUL 18 2005_01.bif(5.71MB) FILE FROM FLASH OG AREA MY DOUBT IS HOW FLASH USING ABOVE FILES IN MULTIBOX? I FLASHED USING FIRST FILE (16384KB) IN VYGIS-STILL SET IN REBOOT.I DONT KNOW HOW FLASH USING MULTIBOX. THANK U |
02-17-2007, 16:36 | #2 (permalink) | |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
2. Start the LG2G tool of the latest version. One socket will began blinking at the same moment - this must be one called "UNI". 3. Go to bookmark "settings" - and select correct com port. In my case multi-box port is 3 ( do not change it ), phone com port is 6. ( is very important to select correct phone com port - in other case you will get always error in connection ) 4. Go back to main bookmark and select correct phone model and working speed. 5. Connect your phone to cable and then plug the cable to blinking socket "UNi" ( phone must be off ). Press "connect" botton and then press the botton +vcc 5V on box. You will see readed info from your phone: IMEI, phone version and model. ( sometimes software don't show you version and model - don't worry - you can continue your work ) If you get error: ERROR - Phone don't answer RF - that mean that selected working speed is not good for this model - try to select slower speed. 5. Select flash files 1 and 2. First flash file is codedata, second - AlchemyData. 6. Press "write flash" botton. Flashing progress starts. Now you can take a cup of tea. 7. DONE Press "disconnect" botton on software. Disconect the phone from box, cable. Reconect the battery and swith on the phone. Phone working - firmware changed! | |
02-17-2007, 17:06 | #3 (permalink) |
Member: 239168 Status: Offline Thanks Meter: 104 | I GOT TWO FLASH FILES 1.L342i_P40FL_V10h_356186002255328_full(16384KB)bi n file FROM FLASH FULL SUPPORT AREA 2.L342iP40-07-V10a-250-01 JUL 18 2005_01.bif(5.71MB) FILE FROM FLASH OG AREA WHICH FILES R DOWNLOAD FROM SUPPORT TO FLASH.IN WINDOW TWO FILES NEED TO FLASH.THAT IS FLASH 1 AND FLASH2.MY DOUBT IS WHICH FILES R SELECT HERE? THANK U |
02-17-2007, 17:22 | #4 (permalink) | |
02-17-2007, 19:53 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | for LG342i reboot if you flash the phone all version stay reboot, just flash it C3320 flash file and your phone will work again |
L03A unlock the wrong phone opens automatically shutdown, please help fix! | liufeifei | Z3X-Team Products | 4 | 02-25-2010 20:08 |
1208 1209 rebooting problum please help | Jazzy_j_2000_uk | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 05-28-2009 08:09 |
M600 Reboot, solved. Unlock - reboot again, please help ! | tian | SETool2 | 1 | 10-02-2008 15:12 |
DOUBT, please help me!! | Matuk | Nokia Multimedia | 1 | 02-05-2005 22:42 |
