02-13-2007, 13:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | need help urgent abot sendo 600 p600 jtag connection |
02-13-2007, 13:54 | #2 (permalink) | |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
product support/multi-box/base software/pinout/sendo/simple_schematics/ sendo_s6xx_jtag.jpg And all will be clear. | |
02-13-2007, 16:24 | #5 (permalink) |
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | sir here is the logs now what is the prob....n wt can i do now? Waiting for ignition... Loading boot.......OK Flash ID: D508D508 - Unkn.Vendor Possible Flash size 8Mb Flash ID2: D508D508 - Unkn.Vendor Possible Flash size 8Mb Updating MCU part... Error! Incorrect Start or/and Length! |
02-13-2007, 16:29 | #6 (permalink) | |
02-13-2007, 16:56 | #9 (permalink) |
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | set come to my shop some time hang ... i just start software and select model... download files from support sites n select in software then connect cable to multibox then set n press connect button connection ok when press button update software button messag on status area mcu flash some like that but not start in 0% n give error shown try again then cell not booting with simple cable connection then i make jtag connection n give this error.... Waiting for ignition... Loading boot.......OK Flash ID:15000500 - Unkn.Vendor Possible Flash size 8Mb Flash ID2:15000500 - Unkn.Vendor Possible Flash size 8Mb Updating MCU part... Error! Incorrect Start or/and Length! now sir what is the prob... i select rite model in selection bar n correct files but prob exist.... what can i do urgent plz flash backup ok... |
02-13-2007, 17:01 | #10 (permalink) |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | 1. Run the software Sendo Tool. And check please your box activation status. Your box must have 5 activations like in a picture. If you dont have "- SND JTAG ST" activation - you need to update the activations - for this you should use Update tool which you may find in support area and it will be activated in 2 sec ( internet connection must be on ). 2. Connect the JTAG cable to phone. Use for this please picture from support area. All 8 wires must be soldered to phone PCB. Be cearfull please!!! If you have incorrectly soldered - you can damage CPU. 3. Connect this cable to box ( you need to use "JTAG" socket ). 4. Select you phone model from models list. Then select please: MCU, LP and CP files for your phone ( all files are like for normal flashing ). 5. So now you are ready. Press power on button on your phone PCB for a shot time ( ~ 1 sec ). Press "Write flash" button on software. You will see next. ( look to the picture below ). If all is alright you will see the progress ( flashing will start ). If no any responce - it means that you have selected wrong phone model or incorrect soldering or CPU chip of the phone is dead. 6. Just wait for a short time - and all will be done. 7. Now you have to check if all is alright or not. Please reconnect the phone ( reconnect the cable ). Then select your phone model in menu. Press "connect" button and when the software asks about ignition - press shortly power button on the phone ( ~ 1 sec ). Software reads all info. Then you need to go to IMEI/Sim Lock bookmark. Check please IMEI ( if necessary - correct it ), check locks ( if necessary - open the locks. For this you can read manual "How to unlock Sendo" ), then press "Default values" button and then "Apply changes" button. Reconnect the cable. Select your phone model, press "Connect" button, when software asks about ignition - press shortly ( ~ 1 sec ) power button on the phone. You will see all info about the phone. DONE. All is clear and you phone has a new life ;-) |
02-14-2007, 09:28 | #11 (permalink) |
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | sir i dont understand where is the prob i alreadly follow these step which u pasted here in manual every carefully now again same prob... i need solution...? |
02-14-2007, 09:44 | #12 (permalink) |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Starnge, if you are making all steps like written it must work, coz I tested it before make this manual. Please be sure that you have selected correct files, model, also be sure that you are using latest Sendo tool. |
02-14-2007, 10:09 | #13 (permalink) |
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | now am again check phone model back of the body is P600 SND600 and its Telefonica Movistar written on upper side of main lcd on body... in software i select SND600 p600 download files again from support site and select files in software n do all procedure in manual bt same sir ..... ? |
hi !!! need help regarding samsung sgh 600 limited service..... | RAHUL12345 | Samsung Hardware Repair | 1 | 05-17-2010 12:44 |
Need Help to unlock sendo m550 | zargalo | Various | 1 | 11-04-2003 07:35 |
need help urgently on c25v08!!!! | ^ares^ | x1x to x45/x50 | 1 | 12-27-2001 01:18 |
6210 dark display need help urgently | gsnbhagawan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-11-2001 22:35 |
need help urgently........... | Nebukadnezar4 | Old Ericsson Phones & Sony Phones | 0 | 07-15-2000 16:28 |
