05-08-2007, 04:10 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Galaxy Age: 46
Member: 86301 Status: Offline Thanks Meter: 107 | vk200 no locks detected...but locked i have little pb with multibox and vk200. so read info ok, but never found lock data....phone is french TELE2 branded please help. (by the way, if it can help , JAF give me the same error) here is the log Phone found... Booting phone... Booting Complete. FLASH_NAME:INTEL 28F256L18T85 FLASH_ROM_SIZE:33554432 FLASH_RAM_SIZE:8388608 FLASH_ID:9013261 FLASH_BASE_ADDR:16777216 FLASH_REGION_COUNT:2 FLASH_REGION_0_SECTOR_COUNT:255 FLASH_REGION_0_SECTOR_SIZE:131072 FLASH_REGION_1_SECTOR_COUNT:4 FLASH_REGION_1_SECTOR_SIZE:32768 FLASH_MAX_SECTOR_SIZE:131072 FLASH_MAX_SECTOR_COUNT:259 PHONE_IMEI:3595020xxxxxxxx Unlocking... No locks detected i have try to rrebuild imei and i have see that multibox as a little bug( first 6 number are ok, but the other ar not ...) thanks in advance for help regards |
05-10-2007, 04:13 | #7 (permalink) |
Member: 86301 Status: Offline Thanks Meter: 107 | Thanks for reply... @The_Gorr i will contact you if i see you online, anyway thanks for help @andy4wisdom : can you explain? wich dll and where to copy/ paste this dll i have try with 3 different pc, win 98 OSR1, WINXPSP1, WINXPSP2 and always the same. i think driver is in cause (see picture) any idea are welcomed regards |
05-10-2007, 13:46 | #9 (permalink) |
Insane Poster Join Date: Apr 2005 Location: china, cambodia, vietnam Age: 44
Member: 132968 Status: Offline Sonork: 100.1619307 Thanks Meter: 12 | hi all. I did phone lock successfully VK200. My phone is phone lock . read info ok , When I unlock software show "No locks detected" . phone same. u solved ur problem using this solution , please contact The_Gorr thank . when i info by MULTI-BOX Phone found... Booting phone... Booting Complete. FLASH_NAME:INTEL 28F256L18T85 FLASH_ROM_SIZE:33554432 FLASH_RAM_SIZE:8388608 FLASH_ID:9013261 FLASH_BASE_ADDR:16777216 FLASH_REGION_COUNT:2 FLASH_REGION_0_SECTOR_COUNT:255 FLASH_REGION_0_SECTOR_SIZE:131072 FLASH_REGION_1_SECTOR_COUNT:4 FLASH_REGION_1_SECTOR_SIZE:32768 FLASH_MAX_SECTOR_SIZE:131072 FLASH_MAX_SECTOR_COUNT:259 PHONE_IMEI:359502000002910 Unlocking... No locks detected |
05-10-2007, 23:12 | #13 (permalink) |
Member: 86301 Status: Offline Thanks Meter: 107 | @The_Gorr .thanks for help phone is now unlocked. but now screen is not good (a line is missing an bottom and the contrast is not good). as someone a good unlocked backup for TELE2 firmare? thanks if i write backup, all is ok but phone locked |
05-11-2007, 14:14 | #14 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | try to read flash from any working vk200 phone and flash ur phone with it, i think it will solve ur problem br <= The_Gorr => |
05-11-2007, 17:42 | #15 (permalink) |
Member: 86301 Status: Offline Thanks Meter: 107 | yes you are right, but i have not another unlocked phone.... so if someone can post here unlocked flash file: VK200_SZ0.93R cause i have only VK200_SZ0.65R and it is not fully compatible. thanks in advance for sharing. regards |
E63 Logs Detected but phone is still lock | aliasif83 | Universalbox | 6 | 04-25-2009 13:58 |
7100s-2 supernova in info it says all locks open but its locked | mainpagul | Universalbox | 6 | 04-22-2009 23:17 |
My 220x Ntwk Lock-tried-but Still In Lock | zone2 | Infinity-Box | 9 | 05-13-2008 08:40 |
Ts605- Locks disabled but always locked | abdoune | FuriousGold | 6 | 12-19-2007 00:01 |
