03-14-2008, 21:50 | #1 (permalink) |
Junior Member Join Date: Mar 2005 Location: PL Age: 42
Member: 129467 Status: Offline Thanks Meter: 0 | How to convert n80 to n73? How to convert n80 to n73? Problem: 1. I made all backups and erased phone using "erase 8mb file", 2. I writed flash from n73 to my n80. 3. When n80 is powering up - whie screen appear... I have HWK and JAF. Please, help me what I must to do - (step by step) (And: When I am flashing my n80 by "n73 flash" - I must choose Phone Model n80 or n73 (in my JAF) ???) Sorry but my English is ... Best Regards Chillouty |
03-15-2008, 04:36 | #2 (permalink) |
Junior Member Join Date: Apr 2007
Member: 498655 Status: Offline Thanks Meter: 0 | make crt backup and pm 308 flash 8mb erase file select manual flash, use ini and select n73 select apac flashfiles and flash it after that pc would detect n73 with damage imei then unlock it read pm 308 again (maybe you will need it) now it a bit problem, that should be because of n80 version that phone had and that you will flash it so the best way is select downgrade, the flash it with n80 flashfiles maybe your phone will be dead after flash, dont worry if phone is dead you will need to write as mcu bb5erase_EE_16MBrap then phone will be alive again but with imei damage and unknown provider write full n80 pm now open the pm 308 that you read in first step and open the pm 308 that you read after unlock it you will see that after unlock it have some more data in the end clear the data that is in excess to be the same blocks as original pm 308 then save it now restore crt backup then write the pm 308 that you edited and saved now make SX4 auth the write full n80 pm again and thatīs all i hope that this help you, with me it works in all n80... with uid its more difficult to put it ready to unlock and revive it again then remove glue and make the testpoint.... |
how to unlock n80 to use all networks | mikeeyb85 | Nokia Base Band 5 ( BB-5 ) | 5 | 04-27-2008 12:39 |
