09-22-2007, 05:56 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | porblem with 6300 spanish flash ic and 5200 with sec flash ic same is with one 5200 and one 5300 with sec flash ic................ could it be unlock with any other box ...... or i can do it with uid ... plz gsm denis help me quickly thanks in advance |
09-22-2007, 09:21 | #4 (permalink) |
Member: 78619 Status: Offline Thanks Meter: 297 | but no answer from uid so its common problem for ur customer dear uid team but no answer from any team member............................................ ............ what we should do now return the fones back to customer or wait for newe update.............. waiting for ur answer br |
09-22-2007, 10:16 | #6 (permalink) | |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | Quote:
For your problem. 5200 you can unlock any without problem. I personaly unlock about 10 pcs with this flash IC without problem and with spannision IC too. Trick for you: Enter phone in local mode and to wrte unlock code use DSS and USB cabel work for me without problem this solution. bye | |
09-22-2007, 19:21 | #9 (permalink) |
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | For 5200 work for all flash IC !!!! Spanision too you need only in software select VAR2 if you unlock spanision flash IC. I try check and work without problems. For 6300 only ou need wait for update for UID team rest phone work without problems. bye bye |
09-23-2007, 17:18 | #10 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | UID must Answer ur Reply aint a solution i tested more then that mate without success.. Its causing problem even downgrading becomming an issue should UID team Ignore these all people keep asking for same problem again and again?????????? |
09-23-2007, 18:00 | #11 (permalink) | |
Member: 78619 Status: Offline Thanks Meter: 297 | thanks for ur reply Quote:
as for my work is concern i am the user of this box when it starts its work and i unlocked many sets by entering codes by hand .......... and for now i am working with dss too and have unlocked many n73 and today also e65 with latest update .......... so u be clear now how hard i can work with this box and i know its great box ......... i found a bug so i decided to post here so that its team must have a look on it ......... these flash ic's also causing problem in other boxes as they r also not able to unlock these phones even the latest one in market ... so uid team take a look and be the first to over come this problem .. best regards br khalid | |
Help with flashing U708 and problem with locked files | buramario | Samsung Flashers, Software, Firmware. | 5 | 07-22-2009 10:08 |
6300 spanish flash ic and 5200 with sec flash ic | uqbah | MT-BOX | 1 | 09-22-2007 07:12 |
Flash 7650 and 7210 with cheap flasher??? | silvester | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 01-02-2003 19:03 |
flashing mcu and PPM with dejan flasher | zbomberman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-2002 11:41 |
