11-08-2007, 04:54 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Solution to unlock K310 CID50 with SeKing We have to convert the K310 to W200 to be able to unlock, as the first isn't supported by SeKing yet. 1. Flashing to W200 Cable Required: DCU-60 USB Select any flash for W200 CID50 and flash and customize your K310 selecting W200 from the dropdown list. 2. Unlock by patch selecting W200 Cable Required: COM cable (I used cruiser cable) - Because SeKing not support DCU-60 unlock for DB2010 platform. Select W200 in the dropdown list and make unlock by patch. Phone unlocked Pros and cons of the K310 -> W200 conversion: - We gain Walkman function, and can use the phone without SIM to hear our favorite MP3s. - The radio function of the W200 don't work (That's because K310 doesn't have radio hardware). |
01-12-2008, 20:43 | #2 (permalink) |
Freak Poster Join Date: Jan 2006 Location: peru Age: 57
Member: 215758 Status: Offline Thanks Meter: 33 | I made it like you explain I enter to the menu of service in sim blockade it leaves me net, net sudconjunto all closed one this problem happened wanting to liberate it direct without your tutorial help Identify Done! Disconnect Phone Success! [ --- Initialize --- ] Open COM4 Success(9600)! Wait For Phone Connect... Phone Connect Success! Baseband IC ID:8040 Protocol Version:0301 Security Model:01 Color: Red EROM CID: 50 CID Version Represent EROM CID! Select CID50 Flash File To Flash! Baudrate Switch To 921600 Success! Send Applet... Applet Version:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 Flash ID: 0x897E IMEI: 35605001222411 OTP LOCK: 1 OTP CID: 50 Initialize Done! [ --- Write Unlock Patch --- ] Send Applet... Applet Version:060721 0900 GENCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B002 1 Connect Server! Connect Server Success! Available Credits:18 Receive Authentication Data Success! Current Left Credits:16 Encryption... Patch 1 For Unlock Network ... Patch 2 For Unlock Network ... Patch 3 For Unlock Network ... Patch 4 For Unlock Network ... Patch 5 For Unlock Network ... Patch For Unlock Network Success! Disconnect Phone Success! Open COM4 Success(9600)! Wait For Phone Connect... Phone Connect Success! Baseband IC ID:8040 Protocol Version:0301 Security Model:01 Color: Red Baudrate Switch To 921600 Success! Send Start Command ...! Send Applet 1... Send Applet 1 Success! Send Applet 2...! Send Applet 2 Success! Send Applet 3...! Send Applet 3 Success! Send Applet 4... Send Applet 4 Success! Send Applet 5... Send Applet 5 Success! Send Applet 6...! Send Applet 6 Success! Read Applet Version...! Applet VersionB2010_R1A002_PRODLOADER_PATCHED_SEKING Escape Secure Check! File Path:C:\gavilano\seking\w200 50\W200_CXC1250719_GENERIC_ME_R4HA014_RED50_sw_enc .bin Flashing,Please Wait... File Path:C:\gavilano\seking\w200 50\W200_CXC1250728_AMERICA_2_R4HA014_RED50_fs_enc. bin Flashing,Please Wait... Flash Success! Unlock... Unlock Done! [ --- Start GDFS and File System --- ] Send Applet... Read Applet Version Failure! UseTime:09:32 |
01-13-2008, 03:21 | #3 (permalink) |
Member: 181633 Status: Offline Thanks Meter: 730 | Nowadays all DB2012 CID50 and 51 can be unlocked directly using the unlock files from support area. So forget about my post from November 2007. @cmagavilano 1. Flash your phone with K310 CID50 firmware from support (Customize if necessary). 2. Download unlock file that match exactly your phone's firmware version (use identify function to know wich file you have to download), put it in folder Unlock_Files inside Seking folder. 3. Select K310 from model dropdown list, tick "49 51 52 Patch(2 credit)" and "49 51 52 Unlock" options, press Go button and follow program's instructions. After few minutes your phone should be unlocked. |
how to unlock k310 with fg | geepee777 | FuriousGold | 1 | 04-15-2008 14:02 |
the real full solution to unlock LG U8550 with FB2 | fethi | FuriousGold | 2 | 02-07-2008 03:18 |
Anyone Unlock K310 Cid50? | edong | Cruiser Suite | 14 | 10-16-2007 17:05 |
any solution to unlock cid50 new version | Unlocksupport | Cruiser Suite | 1 | 07-30-2007 01:39 |
Solution To Unlock Siemens Ap75 With Redbox Here!!!!! | massy | Redbox | 11 | 05-22-2007 21:11 |
