11-13-2008, 19:43 | #16 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
but not the TP way as i dont want to open the phone .. now i want to try cruiser for the first time . so i am asking a lot of questions .. please help me with the method .. i can post setool log here .. thanks | |
11-13-2008, 20:05 | #17 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Pakistan Age: 36
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | Read This: q: when i flashing/completing/etc phone i got error like Code: loader startup: executedLoader refused to start GDFS services,error is:29loader GDFS startup failed, that is fatalElapsed: 734 secs. what to do ? a: that error can be caused by different problems. lets see all of them 1. user has run "executor" application, which was not deleted after "new altbypass unlock". solution - select correct model on settings check only "use preloader security bypass". execute any operation, say : "read flash" 2. main software somehow has been damaged (cause of free tools, etc) solution - select correct model on settings check only "use signed mode". add to firmware area only main part of firmware press flash (use com/ufs or dcu60 with "2+5" keys if phone not connecting with "C" ) after that, phone should show identify normally. .... and if not.... 3. gdfs area has been damaged (bad flash ic, firmware error,etc) solution - a) install empty flash chip and do emptyboard fill procedure b) try to repair gdfs area with VERY complex testpoints c) change both mcu+flash chip from other phone B.R., Sonu |
11-13-2008, 22:00 | #18 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i have done first two steps but the phone is still in same condition .. if the problem is this the ? 3. gdfs area has been damaged (bad flash ic, firmware error,etc) solution - a) install empty flash chip and do emptyboard fill procedure b) try to repair gdfs area with VERY complex testpoints c) change both mcu+flash chip from other phone what to do ? how to repair this with cruiser or setool without making TP? |
11-13-2008, 23:18 | #19 (permalink) | |
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | You Must Do Repair Your Fone With TP here is video manual for TP http://rapidshare.com/files/163515174/TP_Video.rar.html B.R., Sonu Quote:
12-01-2008, 02:43 | #21 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Where Dreams Comes True...S4U
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | Even; setool is the best for sonyericsson mobiles without exceptions.................................. |
can ub repair sony ericson phones in red light fault | SAHIL MIDHA | Universalbox | 4 | 07-28-2009 05:04 |
can ub repair red blink db2020 cid52,53 | sprashant | Universalbox | 2 | 11-29-2008 20:33 |
red blink in db2020 phones | cavi | Sony Ericsson Hardware Repair | 0 | 11-24-2008 15:02 |
@ Lead ! Can we repair K610i CID52 , RED BLINKING ? | rjsoo7 | Cruiser Suite | 7 | 05-21-2007 23:34 |
K610i Red light blinking repair?? | AKKA | Cruiser Suite | 6 | 11-11-2006 12:35 |
