01-17-2008, 19:17 | #17 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Devon, England
Member: 55766 Status: Offline Thanks Meter: 333 | Ive had problems with every version above v0.3.0 always byte 08 but not with v0.3.0. any sugesstions as why gnd is good with that version but not v0.3.1, v0.3.2 and v0.3.3 ??? main problems with 3110c and 6280. They work fine with 6300 and 5300 |
01-17-2008, 20:15 | #18 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Romania Age: 42
Member: 81232 Status: Offline Thanks Meter: 196 | I think is cable problem , me 2 have same problems , but after i change cable have no prob , i use a handsfree wire original nokia , i chose red one for data , shorten gsn , and clk , all phones working good , first try unlock . |
01-17-2008, 20:23 | #19 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | Data and clk seem ok its only gnd according to byte 08 but what puzzles me is its both cables but only with 6280 and 3110 not other fones. It works ok with lower versions of bb5box so why is cable problem only with v3.1 v3.2 and v3.3 but not with v3.0 |
01-17-2008, 22:35 | #20 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: INDONESIA Age: 38
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | Quote:
also change cable from original Handsfree, very short make me get harder when unlocking, but successfully unlocked E62 Cingular today with version 3.1 br, kevin168 | |
01-17-2008, 23:40 | #21 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | Yes I shortened gnd using thicker wire and shortened usb cable from pc to box and unlocked 3110c successfully but I still dont understand why the problem only occurs in versions after v0.3.0 |
01-18-2008, 00:48 | #22 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: Indjija,Serbia Age: 47
Member: 136327 Status: Offline Thanks Meter: 17 | Quote:
xe,xe .......and supporters dont understand why the problem..... I now one thing......my BB5 BOX is for sale,and MT-pro lite incoming in my service !!! B.R. | |
01-18-2008, 03:50 | #24 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | @all mesure first your volatge in your bb5box if it is lower than the voltage require.if it is lower then use acp-12.but if the voltage is sufficient for the required supply then don't use acp-12. br |
01-18-2008, 17:51 | #25 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 189424 Status: Offline Thanks Meter: 18 | 3.3 to profdragraga: go to setting and disable auto and try again, same thing happened with me. last 2 update i could not unlock any (atd) flash chip, with this update cool every thing ok. |
01-19-2008, 01:47 | #26 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Wickford, Es***, UK
Member: 112674 Status: Offline Thanks Meter: 5 | I am now on my third cable and all working fine at the moment, so it probably is a faulty cable. Don't drive yourself mad like I did and get yourself new cables. |
01-19-2008, 09:59 | #27 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | I totally agree with you. I think about 90% of failures is due to cables faulty or breaking down. I think its a MUST to have a few sets that you know are working ie if you have one that is working then buy another, then if you have 2 working sets you can then check if you fail with other set. (cheaper than 2 boxes ) |
Super Doctor 3 Box New Update!Commzero up to 3.420 | MOBIL CLINIC | Service Products News & Updates | 0 | 12-10-2009 12:58 |
super doctor 3 box new update!commzero up to 3.420 | MOBIL CLINIC | Trash | 0 | 12-10-2009 11:00 |
super doctor 3 box new update!commzero up to 3.420 | zhulianqi | Service Products News & Updates | 0 | 12-10-2009 10:52 |
