10-05-2007, 11:02 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | IF ANYBODY UNLOCKED 6280 WITH SECxxxxxETA chipset, PLEASE POST HERE HI IF ANYBODY HAS MANAGED TO UNLOCK 6280S WITH SECxxxxxETA chipset PLEASE POST HERE ALSO WHAT VERSION WAS THE PHONE THANKS |
10-05-2007, 20:50 | #5 (permalink) |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | for 6280 i believe that users have big problems due the small tp's , plz be more carefully. i guarantee u that 6280 all works perfect, no matter what flash chip B.R., Raskal |
10-05-2007, 21:56 | #7 (permalink) |
No Life Poster Join Date: Sep 2002 Location: allsiemens.com Age: 37
Member: 15925 Status: Offline Thanks Meter: 11 | Hello! I have also trouble with ETA chip, i have unlocked many phones like 6280(not ETA),N95,6300,6233,N73,5200 and its working, but i have tried 20 times unlock ETA chip and it don't work. all another chip from 6280 work perfectly. |
10-05-2007, 22:11 | #8 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | for any other chips i can do in less than 3 tries without microscope but always get stuck on ETA chip but finaly i did one after hour's try Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.81_09-05-06_RM-78_(c)_Nokia IMEI: xxxxxxxxxxxxxxx SP LOCK status: Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_35xxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_03.8 1_09-05-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-06-2007, 00:08 | #10 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | I was about giving up but After about 1 hour.. Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.40_20-12-05_RM-78_(c)_Nokia IMEI: 357603002990554 SP LOCK status: Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_357603002990554_Locked_Keycnt_0_Fbuscnt_0__V_03 .40_20-12-05_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull this chipset is a pain in the *** ! BR! |
10-06-2007, 03:54 | #11 (permalink) |
No Life Poster Join Date: Jun 2006 Location: in this world
Member: 292087 Status: Offline Sonork: 1575183 Thanks Meter: 194 | this is my log for SECxxxxxETA unlock sucessfuly Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 357603003391877 SP LOCK status: Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_357603003391877_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-06-2007, 10:32 | #13 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | sorry for a stuipid question, i never unlock a BB5 phone so I have one question? I see that people here unlock 6280 within 1 hours, so must I keep TP in same time? (one hour too or can release TP at special time?) Thanks |
10-06-2007, 12:51 | #15 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | today unlocked one SecxxxxxETA at first try the phone was 3.40 and i upgraded to 3.81 PS: i noticed also the pins (between data pin) are more closer in this phone than the other. |
IF ANYBODY UNLOCKED 6280 or 6233 WITH spansion chipset, PLEASE POST HERE | SGHGSM 3 | BB5BOX | 72 | 01-04-2008 21:00 |
6280/6288 SECxxxxxETA chipset NOT SUPPORTED?? | Trooperx17 | BB5BOX | 10 | 10-03-2007 12:31 |
Please Post Here If you have problem with corrupted file after 16-06-2007 | MicrostarGSM® | MT-BOX | 2 | 06-20-2007 13:13 |
if 1 secuss to unlock with p2k usb smart post here result | Chawkiz_gsm | Motorola P2K (USB-Smart) | 2 | 03-04-2006 12:42 |
Siemens flash/unlocking procedure Who know exactly please post here | market_3b2002 | Siemens-Benq RingTones and WallPapers | 13 | 08-20-2005 15:19 |
