10-10-2007, 09:24 | #34 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Slovakia
Member: 42020 Status: Offline Thanks Meter: 11 | Problem in ETA chip is not solved Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 357603003269586 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_35760300326xxxx_Locked_Keycnt_3_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_357603003269586_Locked_Keycnt_3_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
10-10-2007, 10:06 | #37 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 320134 Status: Offline Thanks Meter: 25 | Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 1000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. plz help me |
10-10-2007, 14:50 | #38 (permalink) |
Member: 320134 Status: Offline Thanks Meter: 25 | Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 1000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. plz help me its urgent |
10-10-2007, 16:46 | #40 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Prijepolje-Durmitor, Serbia And Montenegro Age: 46
Member: 19987 Status: Offline Thanks Meter: 27 | Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.70_28-03-06_RM-78_(c)_Nokia "SAME WITH v6.43" IMEI: xxxxxxxxxxxxxxxxx SP LOCK status: Config Key: 2321000093172790 Block 1: CLOSED Type 5 Data: 23210F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_3XXXXXXXXXXXXXXX_Locked_Keycnt_0_Fbuscnt_0__V_0 3.70_28-03-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_3XXXXXXXXXXXXX_Locked_Keycnt_0_Fbuscnt_0__V_03. 70_28-03-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2321000093172790 Block 1: CLOSED Type 5 Data: 23210F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
10-10-2007, 16:49 | #41 (permalink) | |
Freak Poster Join Date: Feb 2003 Location: Philippines Age: 54
Member: 22588 Status: Offline Thanks Meter: 29 | Quote:
10-11-2007, 12:00 | #42 (permalink) |
Member: 320134 Status: Offline Thanks Meter: 25 | 6233 unlock problem with BB-5 Box Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_05.10_21-12-06_RM-145_(c)_Nokia IMEI:***************** SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-145_352749015331651_Locked_Keycnt_3_Fbuscnt_0__V_0 5.10_21-12-06_RM-145_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-145_352749015331651_Locked_Keycnt_3_Fbuscnt_0__V_0 5.10_21-12-06_RM-145_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. test point is 100% ok Plz help me its urgent |
10-11-2007, 15:44 | #44 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Hmmm By The Looks Of It, It Looks Like That Lot Of People R Having Problems With This Chipset But I Personaly Had Problem On Two Of Them, One Of Them I Unlocked After Several Tries And The Other One I Gave Up But After That I Have Done Few Of Them Without Any Problem And I Am Not Even Using Any Microscope, I Am Using A Magnifying Glass With A Light I Would Agree With Raskal's Earlier Post That It S Bad Tp Or That Can B Testpoint Cable Br |
10-12-2007, 20:04 | #45 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | hi people who r having problems with ETA chips please flash them V6.10 (RM78 DP V343.0 MCUSW06.10.EXE) TESTED BY ME i had 2 with the same chipset(ETA) one was v3.81 and the other one was 6.10 6.10 was unlocked in first try but 3.81 failed tried about 1 hour but no joy then upgraded it to 6.43. no joy then downgraded to 6.10, unlocked in first try br |
IF ANYBODY UNLOCKED 6280 or 6233 WITH spansion chipset, PLEASE POST HERE | SGHGSM 3 | BB5BOX | 72 | 01-04-2008 21:00 |
6280/6288 SECxxxxxETA chipset NOT SUPPORTED?? | Trooperx17 | BB5BOX | 10 | 10-03-2007 12:31 |
Please Post Here If you have problem with corrupted file after 16-06-2007 | MicrostarGSM® | MT-BOX | 2 | 06-20-2007 13:13 |
if 1 secuss to unlock with p2k usb smart post here result | Chawkiz_gsm | Motorola P2K (USB-Smart) | 2 | 03-04-2006 12:42 |
Siemens flash/unlocking procedure Who know exactly please post here | market_3b2002 | Siemens-Benq RingTones and WallPapers | 13 | 08-20-2005 15:19 |
