10-30-2007, 08:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Badong's Junkshop
Member: 260632 Status: Offline Thanks Meter: 639 | 6151 cant unlock always failed help Phone found on FBUS interface Reading phone info ... Type: RM-200 Version: V_03.91_25-09-06_RM-200_(c)_Nokia IMEI: 352284011333725 SP LOCK status: Config Key: 5150300000000000 Block 1: CLOSED Type 5 Data: 51503F Block 2: CLOSED Type 5 Data: 51503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-200_352284011333725_Locked_Keycnt_0_Fbuscnt_0__V_0 3.91_25-09-06_RM-200_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-200_352284011333725_Locked_Keycnt_0_Fbuscnt_0__V_0 3.91_25-09-06_RM-200_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 5150300000000000 Block 1: CLOSED Type 5 Data: 51503F Block 2: CLOSED Type 5 Data: 51503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. always failed |
Blackberry 8830 cant unlock always give e error | MUTUAL | FuriousGold | 3 | 09-24-2010 16:14 |
unlock 706sc always fail help | alpha cell | Z3X-Team Products | 2 | 01-15-2010 11:38 |
6500s unlock always fail | mickle1 | MT-BOX | 1 | 03-07-2009 13:41 |
cant unlock myz55, need help... | reignsmart | SwS_SaG_BoX | 1 | 06-27-2006 16:46 |
cant unlock my100x pls help | Baycell | SwS_SaG_BoX | 0 | 05-14-2006 09:06 |
