04-17-2008, 22:33 | #1 (permalink) |
Freak Poster Join Date: Feb 2003 Location: macedonia Age: 44
Member: 22040 Status: Offline Thanks Meter: 2 | 8600 Alvys This Problem Raskal Help Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-164 Version: V_03.52_24-05-07_RM-164_(c)_Nokia. IMEI: 356287011817221 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 1 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-164_356287011817221_Locked_Keycnt_0_Fbuscnt_1__V_0 3.52_24-05-07_RM-164_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. |
can I solve this problem without help of this lazy reseller? | Ramik | HWK | 5 | 09-18-2008 09:07 |
>> i also face this problem Need Help from Ust Team << | Faisal_Computer | UST Pro II | 6 | 04-07-2008 07:29 |
can u show this 8600 luna unlock problem pls help me9911gt | dharmdev | MT-BOX | 4 | 09-08-2007 17:28 |
hello, pls see this problem and help pls. | ashvin | NSPRO | 5 | 09-10-2006 08:36 |
