![]() | #2 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 391805 Status: Offline Thanks Meter: 29 | reinstall the sortware and then try unlock the fone you should get mt pro is the best sortware for unlock bb5 [email protected] |
![]() | #6 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2003
Member: 28819 Status: Offline Thanks Meter: 222 | bb5 box not bad bro , and it unlock very good i think UID it,s the very bad box ![]() B.R. Mobitec www.gsm-sy.com Last edited by hassan1975; 12-13-2007 at 02:04. |
![]() | #7 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: InsideOut
Member: 333359 Status: Offline Thanks Meter: 91 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.60_10-02-06_RM-78_(c)_Nokia IMEI: 35938xxxxxxxxxx SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_35938xxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_03 .60_10-02-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_35938xxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_03. 60_10-02-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2341500000000000 Block 1: OPEN Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Sure its a bad Box if you dont knowhow to use it. |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004 Location: Galaxy Age: 46
Member: 86301 Status: Offline Thanks Meter: 107 | hi, i have just receive my bb5 box today, and this box is amazing! 1) i have read manual :5 minute 2) install driver , software and active box : 5 minutes 3) connect 6300 v5.00 and fallow step : 2 minutes first fone unlocked unlocked 12 minutes after receive box! i have uid too, and for the same fone, need to flash with supported firmware etc: too long story.... So , congratulation to bb5box team! regards |
![]() | #11 (permalink) |
Junior Member ![]() Join Date: Jun 2004 Age: 62
Member: 70208 Status: Offline Thanks Meter: 0 | If your box reads when you press info and the lights are on it should be ok. I had a similar problem so i purchased new cables from IPMART with new version BB5 software and it worked 100% |
![]() | #14 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: india
Member: 102598 Status: Offline Thanks Meter: 68 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 357926006731009 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_357926006731009_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #15 (permalink) |
Member: 102598 Status: Offline Thanks Meter: 68 | onnecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-200 Version: V_03.91_25-09-06_RM-200_(c)_Nokia IMEI: 352743019747137 SP LOCK status: Config Key: 2140300000000000 Block 1: CLOSED Type 5 Data: 21403F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-200_352743019747137_Locked_Keycnt_0_Fbuscnt_0__V_0 3.91_25-09-06_RM-200_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2140300000000000 Block 1: OPEN Type 5 Data: 21403F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull min 120 phone unlocked by bb5 box |
BB5 BOX - wery bad box | tm-gsm | BB5BOX | 15 | 11-15-2007 16:21 |
red box bad box in alcatel exxx | ..::liragsm::.. | Redbox | 31 | 03-05-2006 21:54 |
