View Poll Results: What BB5 software version are you Using | |||
v 026 | 16 | 18.39% | |
v 027 | 7 | 8.05% | |
v 028 | 64 | 73.56% | |
Voters: 87. You may not vote on this poll |
12-10-2007, 05:10 | #16 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Bulgaria,France Age: 53
Member: 48820 Status: Offline Thanks Meter: 3 | If no any reaction from the SW when the testpoints are connected-just try to change in settings "connection with phone" from enabled to disabled and vice versa.In my case working good when is disabled with 5200,6280,e65,6068.....any supported version.But with 3110c for example im obliged to enable the function and phone unlocked in first try.Never use no any ext. power for no any phone. |
12-10-2007, 05:21 | #17 (permalink) |
Member: 48820 Status: Offline Thanks Meter: 3 | But one of the general reasons why we have treobles i have remarked is that we use frequently the laptops for unlocking.Most of the SWares are working more stable in to the desktops.And this one(BB5box client)is maybe more sensible from the others.Just use desktop;play with the ground;swich off on "connection with phone" and use properly the testpoints and there wil be not not unlockable phone! |
12-14-2007, 02:01 | #18 (permalink) |
Registered User Join Date: Jun 2005 Location: isla pilipinas Age: 19
Member: 153549 Status: Offline Thanks Meter: 13 | im still confused if i will update my box to v028, in reading so many thread of this version v028 that they have so many problems upon updating their box... im still using v026, i have no problem at all in this version.... |
12-14-2007, 15:34 | #20 (permalink) |
Freak Poster Join Date: Mar 2005 Location: egypt Age: 47
Member: 127767 Status: Offline Sonork: 100.1646527 Thanks Meter: 6 | v028............. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.26_16-03-07_RM-198_(c)_Nokia. IMEI: 353230010073290 SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302720 Block 2: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-198_353230010073290_Locked_Keycnt_0_Fbuscnt_0__V_0 4.26_16-03-07_RM-198_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-198_353230010073290_Locked_Keycnt_0_Fbuscnt_0__V_0 4.26_16-03-07_RM-198_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302720 Block 2: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. |
Shopping cart software: What Do you Use? | mfreaks | Off Topic Zone | 1 | 05-21-2012 08:58 |
Poll ..!!!what do peaple need in micro box | CHAGUA | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 20 | 11-25-2009 13:19 |
What do you use to unlock C902! | joer | Sony Ericsson | 5 | 12-10-2008 14:50 |
What do you use to remove transparent glue on IC? | MWP | DreamBox | 31 | 03-30-2008 13:45 |
What do you use to clean the pcb with when there is flux?? | smartfone | Nokia Hardware & Hardware Repair | 5 | 06-24-2005 14:31 |
