02-16-2008, 12:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Heart
Member: 227087 Status: Offline Thanks Meter: 5 | BB5 Box unlock failed nokia 6131 Big Problem.. i have nokia 6131 to unlock but operation failed... here is the log... Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 355536010251480 SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-115_355536010251480_Locked_Keycnt_0_Fbuscnt_0__V_0 6.10_16-02-07_RM-115_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Unlock fail. Please try again. please help what to do its urgent please............. thanks |
02-16-2008, 18:49 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bangladesh
Member: 247758 Status: Offline Sonork: 100.1574842 Thanks Meter: 259 | Bro you are 3 post in the forum for same phone for the same problem.At first you should search before any post.If you don't get any answer then you make post. 2, http:///vbb/showthread.php?t=502075 3, http:///vbb/showthread.php?t=502726 Please read carefully forum rules before post. |
6131 Big problem after unlock!!!!!!! | bistury | Universalbox | 5 | 02-05-2009 04:09 |
BB5 Box Unlocking Fail Every Time. | baljitsb | Nokia Base Band 5 ( BB-5 ) | 6 | 10-02-2008 14:22 |
6131 big problem soft plz help ? | elOSTOra | Nokia Base Band 5 ( BB-5 ) | 9 | 07-20-2008 12:58 |
bb5 phone like n2 ,70,very big problem.. | SAN INFOTECH | Universalbox | 1 | 06-14-2008 05:57 |
Can BB5 BOX Unlock Nokia n95 Black 8gb from three network | Fixtronics | Nokia Base Band 5 ( BB-5 ) | 1 | 01-05-2008 15:34 |
