![]() | #31 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2004
Member: 92178 Status: Offline Thanks Meter: 14 | Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 3576720108***** SP LOCK status: Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 3576720108***** SP LOCK status: Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-174_3576720108*****_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. ![]() ![]() ![]() ![]() BR |
![]() | #32 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2000 Location: gsmdoctor.pl Age: 48
Member: 2755 Status: Offline Thanks Meter: 42 | yesterday had also v5.00 ATD, unlock failed, so as last time did, downgraded to 4.71 (dead), upgraded again to V5.00 (factory def), unlocked in first shot. this method always works by me with problematic ATDs. |
![]() | #33 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2004 Age: 47
Member: 84128 Status: Offline Thanks Meter: 110 | Quote:
thats 10000% correct trick for 5200 | |
![]() | #35 (permalink) | |
Member: 92178 Status: Offline Thanks Meter: 14 | Same here.. Downgraded to 4.71 ( phone dead) reflashed to ver 5 Unlocked now 100% Quote:
Nice one m8.. BR | |
![]() | #37 (permalink) | |
Member: 92178 Status: Offline Thanks Meter: 14 | Quote:
go upto 4.26 or down to 3.71 if you can downgrade that model.. you might be better off starting a thread with the phone model in the title, then this 5200 thread won't drift off, if you know what I mean ![]() BR | |
![]() | #38 (permalink) |
Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() Join Date: Oct 2004 Age: 45
Member: 85712 Status: Offline Thanks Meter: 131 | NK 5200 RM-174 V5.00 - Unlock fail. I have same problem below. How can solved this? Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 353931013993794 SP LOCK status: Block 1: CLOSED Type 5 Data: 72406F Block 2: CLOSED Type 5 Data: 72410F Block 3: CLOSED Type 5 Data: 72411F Block 4: CLOSED Type 5 Data: 21407F Block 5: CLOSED Type 5 Data: 21402F Block 6: CLOSED Type 5 Data: 26806F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-174_353931013993794_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. Flash is ATD. |
![]() | #39 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2005
Member: 202954 Status: Offline Thanks Meter: 32 | hi, here is my first, 5300 unlocking, Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-147 Version: V_04.51_11-01-07_RM-147_(c)_Nokia. IMEI: 354567010315273 SP LOCK status: Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-147_354567010315273_Locked_Keycnt_0_Fbuscnt_0__V_0 4.51_11-01-07_RM-147_(c)_Nokia..bin Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 310160 Block 2: OPEN Type 5 Data: 310200 Block 3: OPEN Type 5 Data: 310210 Block 4: OPEN Type 5 Data: 310220 Block 5: OPEN Type 5 Data: 310230 Block 6: OPEN Type 5 Data: 310240 Block 7: OPEN Type 5 Data: 310250 Block 8: OPEN Type 5 Data: 310260 Block 9: OPEN Type 5 Data: 310270 Block 10: OPEN Type 5 Data: 310300 Block 11: OPEN Type 5 Data: 310310 Block 12: OPEN Type 5 Data: 310490 Block 13: OPEN Type 5 Data: 310530 Block 14: OPEN Type 5 Data: 310580 Block 15: OPEN Type 5 Data: 310590 Block 16: OPEN Type 5 Data: 310640 Block 17: OPEN Type 5 Data: 310660 Block 18: OPEN Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull THIS BOX WORKS GREAT, THANKS BB5 BOX TEAM. BR |
![]() | #41 (permalink) |
Member: 202954 Status: Offline Thanks Meter: 32 | my second 5300 say the following: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_03.92_13-10-06_RM-146_(c)_Nokia. IMEI: 354567010881753 SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-146_354567010881753_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-146_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock fail. Please try again. i tried 2 times and say samething, can somebody tell me what is happening? BR |
![]() | #42 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Damaged SP area. Need RPL. Quote:
![]() | #45 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: Hungary,Deb Age: 58
Member: 10826 Status: Offline Thanks Meter: 19 | 2 pcs 5200v5.00 ATD chip tested. 1-OK, 2-Failed Hi ! 2 pcs. Nokia 5200 v 5.00 full same, sw version, chip type and provider lock same all. 1- Unlock OK ! 2- Unlock Failed ! Error Log: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 35767201171XXXX SP LOCK status: Block 1: CLOSED Type 5 Data: 21601F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-174_357672011714651_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. BB5box unlock algo bad ! Please rebuilding new software to full correct working ! Bakl |
6300 V5.50 ATD chip unlocked successfully with V029 | kushstha | BB5BOX | 0 | 12-15-2007 15:20 |
HELP TO UNLOCK 5200 -V5.50 -ATD cant unlock in ver 5 | CHAPRAN | BB5BOX | 3 | 12-11-2007 14:09 |
5200 V5.0 ATD Chip Cant be unlocked | cocoliso2005 | BB5BOX | 15 | 11-12-2007 21:09 |
5200 v5.00 unlock ok by downgrading 4.71 | ramos | BB5BOX | 5 | 10-01-2007 19:55 |
100% UNLOCK 5200 V5 ATD FLASH CHIP IN NEW EXEBB5_v021 | CHAPRAN | BB5BOX | 9 | 10-01-2007 18:36 |
